What style of radiator hose clamp do you prefer?
JimBee
Has thanked: 25 times
Been thanked: 42 times
Post by JimBee »
Lower radiator hose blew off my 93 850. I thought the shiny stainless steel clamp I'd used there would be good. It was tight but apparently not quite tight enough and over a couple of years there might have been a little seepage around the nipple, enough to make it slippery. Then I suppose it was just a matter of time before the pressurized system pushed the clamped hose over the nipple ridge and from there it blew off.
I found one like this in my miscellaneous bin:
https://www.wdhoseclamp.com/photo-pid18 ... -clamp.htm
Does anybody have experience with this type? Any others that are better?
Has thanked: 1505 times
Been thanked: 3818 times
You’ve reminded me that I have some cheap SS hoses need to purge fro my car
Those closed band type are the ones you want
Has thanked: 1850 times
Been thanked: 1710 times
+1 with abscate on this. This is the original style of the ABA branded clamps Volvo used. Volvo here now sells cheap crap by comparison. Last time around when I needed then I tracked ABA clamps to a Marine supplier in stainless
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 417 times
Been thanked: 457 times
Post by Sveedy »
Maybe another " Not to be left in the junkyard " item...
1999 V70 GLT
rguzz
Year and Model: 1996 850 turbo
Been thanked: 24 times
Post by rguzz »
Go to your local salvage yard and pluck them off any Mercedes Benz.
JimBee
Post by JimBee »
Actually, I got that one from the junk yard : ) along with half a dozen others in my miscellaneous bin. I hadn't used it because the wider ones seem so much sturdier, but while sturdy is good, the narrower ones might actually clinch the hose more tightly. Plus the upturned edges prevent cutting into the hose. Did you notice those clamps cost $ .05 each—if you buy a thousand.
850oldschool
Year and Model: 1996 850 NA
Been thanked: 45 times
Post by 850oldschool »
ABA "made in Sweden" hose clamps are readily available from many sources. I recently bought some for about $4 each, delivered. I like the Ideal clamps also, but they are quite hard to find with a narrow band. It is, however, unsightly to see the rubber of the hose squishing through the slits which are engaged by the screw for tightening.
We should get a group buy together for all of with multiple Volvo’s.
Sveedy
Post by Sveedy »
Or multiple vehicles in general...They all benefit from good clamps. :)
I'd buy a few dozen, at least, of varying sizes...
1999 V70 GLT
amblerman
Year and Model: 1999 s70
Has thanked: 2 times
Been thanked: 70 times
Post by amblerman »
<deleted because I posted in wrong thread>
-A
