Did you know? 🤔
What style of radiator hose clamp do you prefer?
Has thanked: 287 times
Been thanked: 901 times
Trinidad & Tobago
Re: What style of radiator hose clamp do you prefer?
Post by abscate » Wed Mar 11, 2020 2:01 pm
Four things
The open notches cut the rubber into pieces
The bottom of the bolt portion has two sharp edges on the cheap ones which also slice the rubber
The tolerances on the cheap ones suck
The metal quality in the cheap ones is silver cheese and looks like this - yes - these were 'stainless'
Screen Shot 2020-03-11 at 4.02.38 PM.png (732.9 KiB) Viewed 85 times
Link To Volvo Glossary
Trinidad & Tobago
Post by abscate » Thu Mar 12, 2020 6:22 am
abscate wrote:
Wed Mar 11, 2020 3:43 am
We should get a group buy together for all of with multiple Volvo’s.
You can get ABA clamps in durazinc here , from Belmetric
About $2 a piece and they drop to 1.50 USD in qty 10 or more
https://www.belmetric.com/aba-blue-hose ... -6922.html
wizechatmgr
Has thanked: 22 times
Been thanked: 56 times
United States of America
wizechatmgr
Post by wizechatmgr » Thu Mar 12, 2020 11:00 am
I like these for radiator clamps on silicone hoses... Note: This is not the correct size...
https://www.amazon.com/Breeze-Constant- ... 166&sr=8-3
1999 V70 XC AWD - ~187k miles
mecheng
Has thanked: 3 times
Been thanked: 13 times
Canada
mecheng
Post by mecheng » Thu Mar 12, 2020 5:34 pm
Neil is correct you want the European clamps for those reasons on critical hoses and yes my dealer has some of the sizes but for others they sell the generic crap.
I found McMaster Carr a good source, they are German made
https://www.mcmaster.com/screw-clamps
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
amblerman
Year and Model: 1999 s70
Has thanked: 1 time
Been thanked: 27 times
amblerman
Post by amblerman » Fri Mar 13, 2020 8:08 am
That brownish stain is called a corona stain.. No that wasn't a lame attempt at a joke.
See here:
http://www.ngk-sparkplugs.jp/english/te ... index.html
Good description here from the folks at NGK.
amblerman
Has thanked: 1 time
amblerman
Post by amblerman » Fri Mar 13, 2020 9:18 am
Four things
Those are all excellent points. I have been a little spoiled on some of these issue as I inherited a huge number of hose clamps from my dad. He was a sailor and had a lot of stainless clamps rated for marine use. ie: real stainless.
Some/most still suffer from the hose cutting issue but they do not rust.
Year and Model: 2001 V70
Has thanked: 13 times
Been thanked: 40 times
Post by volvolugnut » Fri Mar 13, 2020 10:09 am
Unfortunately, some grades of stainless are not very corrosion proof. Grades 304 and 316 has good corrosion protection. Other grades made have less protection, but can still be called stainless.
2001 V70 T5, 1986 244DL, 1983 245DL, 1975 245DL, 1959 PV544, multiple parts cars.
befarrer
Year and Model: 1998 V70 AWD
Has thanked: 1 time
Been thanked: 4 times
Canada
befarrer
Post by befarrer » Fri Mar 13, 2020 1:41 pm
I prefer the spring clamps, they allow for heat expansion and contraction. Give the right pressure on the hose too. Just a pain to install and remove.
98 V70 GLT AWD
01 Focus Wagon SOHC 5-speed
93 Mazda B2200 with 13B rotary engine swap
Clemens
Has thanked: 89 times
Been thanked: 45 times
Austria
Clemens
Post by Clemens » Fri Mar 13, 2020 2:15 pm
While I don't doubt what you say, this is weird. What's the point of stainless that isn't stainless?
Summer: 1996 855 R
Winter: 1994 855 T5M
Donor: 1995 854 10V
Post by volvolugnut » Fri Mar 13, 2020 2:29 pm
Stainless steel is a generic description. The actual grade tells the true characteristics of the material. The various grades can be magnetic/ nonmagnetic, corrosion resistant or not, weldable, easily machined, very strong or weak, etc. As in most industrial stuff, you need to know the details.
A comment on the constant torque type hose clamps: in a previous job, we only used this type on radiator and turbo hoses of industrial diesels. All others would blow off under pressure. We also found we had to restrain the hoses so they could not move outward from the hose nipple and slide off. When the turbo hose blew off the engine immediately stopped. When radiator hoses came off, you wanted to be aware and immediately shut down the engine.
