The radio and Nav will randomly reset as you are driving the car. Can happen a couple of minutes after you start driving. You may only happen once and the radio/nav will continue working again. Or.....it can happen again a few minutes later. Not shock sensitive because it can happen standing still.
What happens is the Volvo emblem comes on the central display and the radio stops working. If you are on the Nav. display, the map freezes and the whole subsystem reboots like you just started the car. Its like there's a power interrruption to the radio/nav. The car continues to run - no stumbles.
Car is a 2017 V60 w/ 35K miles. Was serviced at 30K by Volvo. The only thing that happened recently was that the TPMS system lost its mind. Reported a low tire but there wasn't one. Recalibrated the TPMS after the tires were checked for proper (38PSI) pressure. TPMS warning went away....... Any thoughts?
2017 V60 Random radio and Nav resets
Runninute08
- Year and Model: 2017 v60
I am having a similar issue. It is very sporadic. Usually once a month. Last week for a whole day it was happening every 5 minutes, but resolved it self the next day.
I have a 2017 v60 with 95k
- 1690 Views
Last post by maclilly
- 2102 Views
Last post by 15volvosncounting
- 1509 Views
Last post by JodyMi
- 5741 Views
Last post by carlosabh71
- 962 Views
