Coil packs
Joelcotten
Year and Model: 2004 S80
Post by Joelcotten »
I had a misfire code so decided to replace plugs and coil packs. During the process discovered bare wires on the coil pack plugs. Wrapped them in tape and now the car won’t start. Help please!
RickHaleParker
Been thanked: 977 times
Post by RickHaleParker »
You might of blew the coil pack fuse when you where working on it. Check fuse 11B/11.
The mounting bolts are the grounds, make sure they are clean and the cam cover is clean at that spot.
Active
Past
SuperHerman
Been thanked: 207 times
Post by SuperHerman »
What RickHaleParker stated plus make sure you didn't turn around any of the connectors and have everything connected.
By the way - what exactly is the vehicle doing other than not starting? Some details, including smell.
