I've been looking for a car for my son and found a 2007 Volvo S80 3.2 with 121k. I was encourage to buy it due to great online repair support here.
I purchased a carfax report and it looks like the two previous owners did regular maintenance. The reseller revealed that they put in a new power steering pump and that the dealer he bought from had put in a water pump. (neither item in carfax).
A test drive didn't reveal any negatives. Ride is nice and has decent engine performance. A couple troubling items are that the fresh air hose from the front grill was missing, (air box seems loose so maybe I'll find hose at the bottom of engine), the complicated hose from air box to throttle body has a little squarish appendage that had RTV on it. So keeping an eye on these issue (ordered new fresh air hose to grill).
From post by PGill I'm alerted to possible thermostat issues and will watch that. I did see fro Carfax where it was serviced for a "noise" and had coolant hoses replaced, but that was back around 87K.
Wish us luck, pick it up tommorow!
Just bought 2007 S80 3.2 121K
- Skymongrel
- Year and Model: 2023 XC90, S80 2007
- Has thanked: 20 times
- Been thanked: 23 times
- Skymongrel
Well...found my first problem with new used S80. Windshield Washer doesn't work! I have some fluid leaking from reservoir, but my headlight washers do work!
If you done this let me know. Meantime I'll do some searching...so far no luck.
Thanks!
Thanks!
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
If the reservoir is cracked use a hot glue gun after thoroughly fine sanding and cleaning with 90+ percent alcohol. Make sure the hot glue is very hot and used liberally. This worked for the coolant overflow reservoir (not expansion tank) on my 03 Odyssey, going on 3 years. Good size hole as it sat on the serpentine belt while running after a radiator replacement. Forgot to put the reservoir back into the mount when I went on a test drive.Skymongrel wrote: 14 Mar 2020, 10:56 Well...found my first problem with new used S80. Windshield Washer doesn't work! I have some fluid leaking from reservoir, but my headlight washers do work!
Thanks!
- pgill
- Year and Model: 2010 S80, 2008 LR2
- Has thanked: 120 times
- Been thanked: 189 times
Congrats on the S80 purchase
My Son is driving the 2010 S80 that I bought for him.
I do get to fix it. (although it doesn’t require much fixing)
Back to the problem at hand
First Roberts suggestion is an excellent starting point.
I looked on FCP and it seems that there are two pumps one for the windshield and another for the headlights.
https://www.fcpeuro.com/products/volvo- ... 35#fitment
https://www.fcpeuro.com/products/volvo- ... 38#fitment
My 2009 Audi has a similar configuration and the pump failed and leaked.
I haven’t fixed this part on my Volvo
Don’t forget to get new grommets too
https://www.fcpeuro.com/products/volvo- ... et-8678424
https://www.fcpeuro.com/products/volvo- ... t-30655139
Good luck
Paul
Good luck
Paul
- Skymongrel
Is the best way to repair this the front bumper removal or can it be done through the fender liner?
Thanks!
Also, perhaps I should post another topic as I find issues with our new ride...but the front exhaust hanger is rusted off. Position on car is just aft of the front seats underneath. I've searched online and can only find rear hangers.
Thanks!
Thanks!
Thanks!
- pgill
Take a look at this video
It’s for a XC70 but I suspect it’s similar to the S80
If it is similar then one of the pumps is accessible by removing the liner from the wheel well
But the other one doesn’t seem to be
Thanks
Paul
PS is you want to watch fun Volvo repair videos then the guy I posted the link too is good but MoVolvo also has many interesting videos
Thanks
Paul
- MoVolvos
According to these folks no bumper removal was necessary. Not sure of your setup so take a look at the diagrams.Skymongrel wrote: 15 Mar 2020, 07:09 Is the best way to repair this the front bumper removal or can it be done through the fender liner?
Thanks!
Thanks!
http://volvospeed.com/vs_forum/topic/17 ... reservoir/
I took a quick look but didn't find the windshield washer system. They sometimes list parts diagram in one year but not another though it's the same model year run.
https://www.volvopartswebstore.com/cars ... parts.html
- Skymongrel
Regarding the best way to get to the windshield washer pump;
I was able to remove the flat plastic bumper apron (called a protection plate located under the bumper) to get to the washer pumps. I removed about 8 screws and three large plastic clips to remove this part. Be careful the washer electrical connector is attached to the plastic apron with a removable connector.
Once removed I had clear view of the washer reservoir and pumps. Everything looked in order, no crimping of fluid lines or corrosion of connectors. I pried loose the windshield washer pump by carefully pulling it out and apply 12v to the contacts. The pump didn't respond so I believe it is the problem. I've order a new one and should have it soon. I should mention that the rubber grommet (which also acts as a debris screen) although intact on removal, disintegrated in my hands.
- Skymongrel
Installed my new windshield washer pump and rubber bushing/screen today. I now have working windshield washers! Yay!
I purchased a after market pump at a reasonable price but did notice that it had problematic electrical connectors. I read a review warning about this so I was careful. The pin are easily misaligned within the connector so if the connector doesn't seat readily, tweak the pins a bit!
Now that washers are working I discovered a cracked t-connector at my washer spray nozzle! Oh boy..so much fun!
- 1419 Views
Last post by mydamnvolvo
- 1543 Views
Last post by pgill
- 1480 Views
Last post by oragex
- 1413 Views
Last post by dosbricks
- 1201 Views
Last post by owen850
