Hi all,
I’m currently looking at replacing my MAF sensor on my 1994 Volvo 940, and it turns out it’s not an easy part to find. I really don’t want to buy that new OEM stuff made in China or any of the aftermarket ones. I’d prefer the original spec ones.
I have found one that looks to be the same but is a different part number, I was wondering will it work?
My part number: 0280212016 (Bosch)
The one I found: 0986280101 (Bosch)
They’re both for Volvo 940.
Thanks
Different MAF Sensors Topic is solved
- RickHaleParker
- Been thanked: 980 times
0280212016 supersedes 0986280101. Both numbers will work.
Active
Past
Past
Ok thank you. It’s good to know I can go ahead and order. It’ll definitely put a dent in the wallet. Just out of curiosity, what did you mean by supersedes? As in it was a revision of the original?, or was it just the same thing but used in special models of the vehicle?
- RickHaleParker
Take the place of ... supplant.
Active
Past
Past
- RickHaleParker
May of found a better or lower cost way to do it that required a new SCD ( Source Control Drawing or Specification Control Drawing ) which would require a new part number.Mn10 wrote: 14 Mar 2020, 00:23 Yeah no, I knew that. I was just trying to figure out what the difference was, as in why Volvo chose to make a newer part for the exact same model of car.
Active
Past
Past
- 1100 Views
Last post by sepress1
- 11846 Views
Last post by packetfire
- 1969 Views
Last post by albertoVO5
- 26 Replies
- 6786 Views
Last post by ChadLee
- 3201 Views
Last post by itsmekirby
