Any tips to get lower oil line off the radiator?
TheOtherside
Year and Model: 1998 V70R
Has thanked: 55 times
Been thanked: 5 times
Post by TheOtherside »
Can NOT get this to come out. Any tips?
98 V70R
13 Flex w/EcoBoost
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
You may need a cut off procedure.
Please read this thread for scope and opportunity viewtopic.php?f=1&t=54118
jreed
Has thanked: 384 times
Been thanked: 221 times
Post by jreed »
Tricky! It should pull directly out, but the rings and spacers are probably preventing it from releasing.
If you have a pair of panel clip pliers, those might allow you to get it out.
Screen Shot 2020-03-14 at 4.23.35 PM.png (129.91 KiB) Viewed 2041 times
TheOtherside
Thanks guys. Were double teaming it and it just wont come out.
Trying not to break the radiator. Lol.
98 V70R
13 Flex w/EcoBoost
TheOtherside
Sat in PB Blaster for a few hours. Still wont budge.
The housing that it fit into spins, so I most likely broke something.
98 V70R
13 Flex w/EcoBoost
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
Can you fill the radiator and see if the connection now leaks? If it leaks, then just hack at it to disassemble and order the new radiator.
TheOtherside
I will do that! Doesnt look like its leaking right now. But I'll fill it up!
98 V70R
13 Flex w/EcoBoost
Has thanked: 1610 times
Been thanked: 4065 times
Fitting is brass and won’t break. Maybe lock on a vice grip and use that as a pry point to pop out
Replace it, and find the oil line rebuild thread to keep that cheap.
Or I’ll send you used ones
TheOtherside
abscate wrote: 15 Mar 2020, 08:57 Fitting is brass and won’t break. Maybe lock on a vice grip and use that as a pry point to pop out
PB Blaster for a day and a half. Wrenches, Channel locks, pliers, rubber mallet. This this absolutely will not budge....
Sucks, because it's the only thing holding me back. Oil thermostat is off and I got new brakes all around. Just need this lower hose off and I get to drive her again.
98 V70R
13 Flex w/EcoBoost
jreed
Post by jreed »
Good luck. It would be a pain to have to replace the radiator too just because of a stuck engine oil cooler hose.
I removed the oil thermostat a few years ago and I remember it took me a long time to get the rectangular o-ring to stay put in the groove so I could tighten up the two bolts.
