I am in the process of repairing the throttle.
Over a year ago, I replaced the sensor with a halotron one because of the ECM-91B7 error.
After the exchange it was great for a long time. Until the day before yesterday, when the error reappeared and the car started very hard in the cold engine.
I decided to take out and clean the throttle.
After cleaning, I caught that the flap stuck a little ... I made a movie:
https://youtu.be/PvP_5oy5NCM
After cleaning it is a little better but still stutters. Is it normal? Can it be repaired somehow besides cleaning or WD-40?
Thanks for any advice
Please. Help me with this throttle
- chris11211
- Year and Model: 2006 s60 2.5T
- Has thanked: 7 times
- Been thanked: 29 times
Hmm. Those units are not reliable, that much I know. And since no one has given you advice in a while, i'd say order a new/used one if you can. Otherwise, you could try and clear the memory and have the car re-learn the idle parameters if you want to re-install to see what happens.
Christ sake don't use WD-40, there's throttle body cleaner for a reason, and try not to get it inside the unit through the flap.
- SuperHerman
- Been thanked: 207 times
What is the maker of the Throttle Body and mileage on the engine. Also what color is the sticker and does it have a build date?
If the throttle body is suffering from connectivity problems due to the ribbons failing - you can try a contact less conversion.
I did this on my 2001 XC70 with great success.
If you have VIDA or access to VIDA it has a robust test for the throttle body - it will be pretty determinative.
I hope we are talking the same part.
I have vida from aliexpress and know those things. I have replace TPS sensor to contactless sensor obe tear ago and was good till now.
I have ECM- 91B7 fault and very hard to start the engine.
Spark plugs are new , rest is ok. I was thinking that could be a faulty throttle possition...
Afer i clean this throttle and put to the car today i have the same problem with starting and with this faulty code...
- 928 Views
Last post by 850TurboTurtle
- 2241 Views
Last post by jonesg
- 1517 Views
Last post by Dragoz001
- 1193 Views
Last post by maraschino
- 3072 Views
