I got a fault code for my VVt valve, so i removed it and after watching some informative youtube videos tested it and fairly sure its faulty.
Applyed 12v to it and it clicks but nothing moves. Reversed polarity and same thing.
Found my spare VVt valve and it tested but the plug is different took a guess all green was ground and green/white was 12v.
Is this valve non polarity? only two wires one goes to 12v the other goes to the ECM...
old style VVt valve to new style question
- darrylrobert
- Year and Model: 2001 v70xc M58
- Been thanked: 27 times
1981 260 GLE converted to 240 M46 after auto box failure
1987 740t auto converted to M47
1997 V70t5 auto converted to M56
1998 V70 factory M56 (parts car)
2001 XC70 factory M58
2002 XC70 auto (parts car)
- Has thanked: 1611 times
- Been thanked: 4075 times
Green Orange takes 12 Volts DC from the main really 2/32 via fuse 11B/5
Yellow Brown is the control signal which is grounded by the ECM to control VVT solenoid position
Polarity will be important.
The new style was designed for cars with DUAL VVT, so the connectors don't bump into each other - functionally identical to the old.
The solenoid shunts oil on a duty cycle , so it won't click open and closed like a typical one.
Fault codes for VVT are pretty reliable, and a junkyard is good source for replacement.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
I noticed no polarity when I tested mine. If it clicks when the engine is HOT - so when the solenoid is hot as well, it's fine, it's hard to see the thing moving inside www.youtube.com/watch?v=U3w3kLF0-I4
VVT solenoid codes may also come if the VVT hub was not pre-tensioned. When you look at the hub from the side (pop the cover), the three securing bolts, are they in the middle of their groove ?
- darrylrobert
Ok my wire colours are different, according to this wiring diagram from 2002 v70 i am just going to connect wire from connector pin1 to pin1 of the new connector. Fingers crossed that should work.
see figure 8/18
see figure 8/18
- - Pete -
- Has thanked: 81 times
- Been thanked: 178 times
Look closely at the plug ends. You should be able to identify numbers in very small print in/on the electrical connector housing, use your original for reference. I had to do this on our 2001.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
Put the one with12vdc on it (key on) onto terminal1
- darrylrobert
Ok thanks all, here are some pics for anyone doing the same.
2001 xc70 wires are red/yellow ecm connector 2, blue/grey 12v terminal 1
2002 xc70 wires are blue/white ecm connector 2, blue/grey 12v terminal 1
Ive read some posts of people buying these in a kit without the plug
- 2471 Views
Last post by krhodes1
- 1175 Views
Last post by ggleavitt
- 1519 Views
Last post by skippy764b
- 5238 Views
Last post by LT South Africa
- 4383 Views
Last post by jimmy57
