I'll be performing maintenance on the server March 31. I'll try my best to make interruptions as painless as possible. Thanks for your understanding.
Did you know? 🤔
New Head gasket or new motor? 2005 Volvo S60R
2001 - 2007 XC-70
humanatek
Year and Model: 2005 S60R
Has thanked: 9 times
Been thanked: 0
United States of America
humanatek
Post by humanatek » Tue Mar 17, 2020 3:51 pm
I"m a long time SILENT LURKER on this site, but have finally reached a matter where I could really use the community's collective GENIUS and INSIGHTS:
So my brother's 2005 Volvo S60R sedan, 6spd manual, seems to have a minor head gasket leak. It smokes white. We thought he'd blown the turbo, since we thought we'd seen a little "blue" in the smoke, but the mechanic is saying we have a "little water" in the cylinders... and that the head is blown...
WHAT DO YOU GUYS THINK??? Should we just do the headgaskets and inspect the bottom end while I'm in there, or just replace the entire motor with a used one?
Thoughts? Prior experiences? Any input or resources would be appreciated.
UPDATE: The mechanic has offered to install a salvaged motor for $2350.00 USD labor. If I source my own motor. Sighhhhhhhhhhh?
Reason: Edited subject title. Please, no "ALL CAPS"s in titles.
BlackBart
Has thanked: 68 times
Been thanked: 51 times
Sweden
BlackBart
Re: WHAT WOULD U DO? New Head gasket or new motor??
Post by BlackBart » Tue Mar 17, 2020 7:08 pm
I only jump in because I happened by early, I put my P2 head back on with a new used cam, and I replaced what I thought was a good Audi engine with used not too ago. Replacing was a pretty big job time-wise. Others here will have way more direct experience for you.
My questions would be:
How many miles on the car?
A used R engine? (not just some turbo motor)
Same year and harness / modules as his?
Less miles or more? (I put the exact 130k Audi engine in, but rebuilt all the systems and accessories)
Do you know what caused it yet?
Is there any damage to the bottom end, or just a leaking head gasket?
My gut would be rebuild the head and put it on, checking it for flatness carefully. Depends on the cost vs a good used motor. Would it be a wash to go either way? The mechanic would do the head replacement as well, not you guys?
My vote is do the head.
These users thanked the author BlackBart for the post:
humanatek
1994 850T wagon
Is it time for a 1964 122 wagon?
humanatek
Been thanked: 0
humanatek
Post by humanatek » Tue Mar 17, 2020 7:40 pm
Thanks for your reply... I saw a motor, an R motor, for sale at 1200 USD, I could DIY it myself, as I've rebuilt Alfa motors before, which have got to have served as some PAIN TEST for this kinda project yes? Otherwise, I would rather redo my head gasket myself, I'd rather, replace the gasket, making sure it's replaned to an anal flat level, maybe even get the head machined and air flowed, along with a new turbo? It's now about cost. The motor being offered is just under 100K miles... so hopfully I"d have at least 30k troublefree miles...
vtl
Year and Model: 2005 XC70
Has thanked: 3 times
Been thanked: 56 times
vtl
Post by vtl » Tue Mar 17, 2020 9:00 pm
Given it's R, new gasket won't help. Need another engine.
These users thanked the author vtl for the post:
humanatek
05 XC70 260k, 16 XC60 40k, 19 Tundra 1k
RickHaleParker
Been thanked: 479 times
RickHaleParker
Post by RickHaleParker » Tue Mar 17, 2020 9:01 pm
I would take the head to a machinist rather then a mechanic and have the machinist check the head out before making a decision.
I have a 2004 S60R I got last week as a $500 mechanics special. Antifreeze in the crankcase, multiple cylinders and the charged air pipe. The above is what I am going to do. Unless I find a cracked cylinder wall.
If it is decided a new engine is the way to go:
The B5244T5 (2.4L) out of the 2005–2009 S60 T5 and 2005 - 2007 V70 II T5 is the exact same engine as the B5254T4 (2.5L) in that 2005 S60R. With the exception of the cylinder bore 81 mm vs 83mm and the fuel injectors.
Just transfer the injectors and R covers and drop in the B5244T5. You maybe able to find a better deal on a B5244T5 because it associated with the T5 badge rather then the R badge and there are more B5244T5 then there are B5254T4.
Another option is to find a short block with a stroke of 93.2 mm and transfer the head from the B5254T4. There are a lot of short blocks that will work.
Last edited by RickHaleParker on Wed Mar 18, 2020 3:40 am, edited 7 times in total.
Platform: P80 1998 C70, B5234T3, 16T, AW50-42, Bosch Motronic 4.4, Special Edition package, Plant: Uddevalla Sweden.
Platform: X40 (Nedcar) 2003 S40, B4204T3, 14T twin scroll AW55-50/51SN, Siemens EMS 2000. Plant: Born Netherlands.
Platform P2 2005 XC90 T6 Executive, B6294T, 4T65 AWD, Bosch Motronic 7.0, Plant Torslanda Sweden.
Platform P2 2004 S60R, B2524T4, AW50/51 AWD, Bosch Motronic 7.0, BorgWarner K24 turbocharger, Plant Ghent Belgium.
RickHaleParker
RickHaleParker
Post by RickHaleParker » Tue Mar 17, 2020 9:04 pm
What does it being a R engine have to do with it?
vtl
vtl
Post by vtl » Tue Mar 17, 2020 9:06 pm
Much more prone to cracked sleeves.
RickHaleParker
RickHaleParker
Post by RickHaleParker » Tue Mar 17, 2020 9:12 pm
Just toss it because it is more prone? That would be a unnecessary waste time and money.
vtl
vtl
Post by vtl » Tue Mar 17, 2020 9:18 pm
What would you do with a cracked cylinder sleeve?
- Pete -
Has thanked: 48 times
Been thanked: 64 times
- Pete -
Post by - Pete - » Tue Mar 17, 2020 10:07 pm
If the block is salvageable you’re looking at $900-1k just for sleeves (aka Darton’s - that’s sleeves alone, extra bucks will be machining the block etc). But that’s just the tip of the iceberg. If it’s a cracked sleeve.
This is a painful discovery & has been documented even on R’s making stock power. I truly hope it is not the case for you & your bother.
On mine, I’m taking every measure I can to avoid a cracked sleeve - maximize cooling & good tuning. Larger radiator, bigger Intercooler, bigger oil cooler, & a properly designed tune to tie it together. Oh, and driving conservatively!
2001 V70XC 146k
2004 V70 AWD 139k
2004 V70R M66 143k
2004 XC70 283k
2006 XC70 155k Sold
