Did you know? 🤔
Engine died while driving and won't start.
valvolvo70
Year and Model: 1998 V70 T5
Has thanked: 5 times
United States of America
valvolvo70
Post by valvolvo70 » Wed Mar 18, 2020 1:39 pm
Back here again for your help pleeese! Yesterday my 98 V70 T5 236K died with no warning on the way back from the grocery store (needed Franks hot sauce, very important). All dash lights were on, no power steering, brakes etc. and was able to coast in neutral to a side road less than a mile from my home. Tried to start again (turned over fine) but didn't fire up. Had it towed to my home today and checked MAF, jumped fuel pump relay, fuel in rail (I can hear the fuel pump prime), dist. cap/rotor (new @ 220K) and general overall check. Noticed today that when I turn over the engine, 3-4 cycles, the engine suddenly acts like its trying to backfire (more like a thud), but only once, and stops cranking altogether. I can repeat this issue with regularity. My previous, issue which I posted here "rough idle, stalls", resulted in replacing the crank position sensor, coolant sensor, thermostat, cam position sensor, swapped a used coil, cleaned air idler and finally, the fuel pressure damper which solved all my issues for a 18+ months. Also checked fuses and timing belt, all good. Generic OBD codes 440 and 455 which have popped up before.
The only other post I found on MVS with similar symptoms was from "kjhiggins" and that fix was due to exposed/worn engine wire harness. I haven't checked the harness yet, not sure where that's located or how to remove for inspection.
Thank you-David
RickHaleParker
Has thanked: 3 times
Been thanked: 488 times
RickHaleParker
Re: Engine died while driving and won't start.
Post by RickHaleParker » Wed Mar 18, 2020 2:33 pm
valvolvo70 wrote: ↑
Check the timing. It may of jumped a tooth or two. A few years back I bought a $3500 S40 with these symptoms for $500. The tensioner had broken and the timing belt jumped, just enough to cause a no start condition but not interference.
Platform: P80 1998 C70, B5234T3, 16T, AW50-42, Bosch Motronic 4.4, Special Edition package, Plant: Uddevalla Sweden.
Platform: X40 (Nedcar) 2003 S40, B4204T3, 14T twin scroll AW55-50/51SN, Siemens EMS 2000. Plant: Born Netherlands.
Platform P2 2005 XC90 T6 Executive, B6294T, 4T65 AWD, Bosch Motronic 7.0, Plant Torslanda Sweden.
Platform P2 2004 S60R, B2524T4, AW50/51 AWD, Bosch Motronic 7.0, BorgWarner K24 turbocharger, Plant Ghent Belgium.
valvolvo70
valvolvo70
Post by valvolvo70 » Wed Mar 18, 2020 3:45 pm
RickHaleParker wrote: ↑
valvolvo70 wrote: ↑
Interesting Rick. Just before it died, I let the turbo spool up and goosed it (not pedal to the metal) for a bit of fun. I'll take a closer look at the timing/timing belt tensioner, it has 100K on it.
RickHaleParker
RickHaleParker
Post by RickHaleParker » Wed Mar 18, 2020 3:47 pm
valvolvo70 wrote: ↑
it has 100K on it.
The S40 had 110K at the time.
These users thanked the author RickHaleParker for the post:
valvolvo70
Has thanked: 287 times
Been thanked: 902 times
Trinidad & Tobago
Post by abscate » Wed Mar 18, 2020 7:58 pm
You are about 50% over the timing belt lifetime
Link To Volvo Glossary
RickHaleParker
RickHaleParker
Post by RickHaleParker » Wed Mar 18, 2020 8:22 pm
abscate wrote: ↑
100/70 * 100% = 142.8 %
New CRP/Contitech TB331 100,000 miles.
valvolvo70
valvolvo70
Post by valvolvo70 » Thu Mar 19, 2020 8:28 am
abscate wrote: ↑
Timing Belt Tensioner (FCP previous owner replacement) has 108K miles.
Timing Belt (Continental) has 29K miles. Previous owner noted that the tensioner looked good at the time of replacement.
Year and Model: 2001 V70
Has thanked: 13 times
Been thanked: 40 times
Post by volvolugnut » Thu Mar 19, 2020 8:51 am
Might have blown off the high pressure hose from turbo.
2001 V70 T5, 1986 244DL, 1983 245DL, 1975 245DL, 1959 PV544, multiple parts cars.
Clemens
Has thanked: 91 times
Been thanked: 45 times
Austria
Clemens
Post by Clemens » Thu Mar 19, 2020 1:33 pm
+1 on the charge pipes.
Happened to me once, was a quite similar result. Lots of lights, not running. They may pop off or rip. If they are ripped, duct tape is a quick fix.
Summer: 1996 855 R
Winter: 1994 855 T5M
Donor: 1995 854 10V
valvolvo70
valvolvo70
Post by valvolvo70 » Sat Mar 21, 2020 1:21 pm
Clemens wrote: ↑
Checked both pipes and they're tight, didn't feel or see cracks/tears either.
