Hello,
My 2000 V70XC has been experiencing a rough 3rd to 4th upshift. Specifically, if I am going uphill and it needs to drop into 3rd gear, it will do it just fine. Once I crest the hill and it shifts into 4th, especially if I also let foot off the gas a bit, I often get a fairly long (about a full second) shudder, then thud.
Have any of you experienced this symptom? Any suggestions on what to do?
-Eric
2000 V70XC has a rough 3 to 4 upshift for Aisin 50-42LE
Richard99
- Year and Model: 2000 V70XC
- Has thanked: 26 times
- Been thanked: 23 times
Eric
1998 Volvo V70 - rear-ended and totaled
2000 Volvo V70XC
2007 Volvo V50 T5 AWD M66
2000 Volvo V70XC
FlyingVolvo
- Has thanked: 51 times
- Been thanked: 74 times
That transmission (I have it) does sometimes have a rough shift or two during normal operation. I've experienced the same thing occasionally on my original trans (lasted 280K before swapped due to large leak) and my current one (used w/~150K).
I would just do a couple drain & fills with good transmission fluid and not worry too much unless it it much more pronounced.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
- 1158 Views
Last post by ZionXIX
- 678 Views
Last post by Richard99
- 1307 Views
Last post by alschnertz
- 1003 Views
Last post by jimmy57
- 468 Views
Last post by hausmeister
