Can anyone tell me what this code means? I just bought an 04 v70 that is a real gem, low mileage, orig one owner & garaged. I messed up by removing the pass front seat without disconnecting the battery first and set off a SRS hard code.
Just got a scanner, and ran all of the codes. Nothing serious, but the code ccm-007 keeps reappearing after clearing as pass comp temp sensor/temp damper motor position sensor.
Additionally, where is the tailgate washer motor relay located? This popped up also.
I would like to thank everyone on this forum for providing Excellent information on how to solve all the small problems, quirks and glitches of Volvos--you are the greatest!
Steve
code ccm-007
- RickHaleParker
- Been thanked: 980 times
Passenger compartment temperature sensor.
Either there is a problem with the supply voltage to the sensor or the sensor is defective. It is located behind the three slits in the Climate Control panel.
Active
Past
Past
- 3950 Views
Last post by Blacklab467
- 1924 Views
Last post by sd4sweet
- 1673 Views
Last post by egoudriaan
- 3041 Views
Last post by blandis
- 2540 Views
Last post by Volvo Kush
