Dash lights flashing along with seatbelt light on visor and all gauges going to zero
Angusthethird
- Year and Model: 2003
- Has thanked: 2 times
this happens after the car has been driven a few miles,flashes about 10 times and quits,only after it has been driven and warmed up.?? battery going bad?
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Well, test the battery by undoing the negative, leave 1h, see how much V
But yours being a 2003, more likely faulty DIM - search forums, Ebay repair service $150 battery HAS to be disconnected while removing it
- yagger
- Year and Model: V60 2016
- Has thanked: 6 times
- Been thanked: 39 times
If you have this problem after engine stay worm, I think issue can bu in the CEM also.Angusthethird wrote: 24 Mar 2020, 14:20 this happens after the car has been driven a few miles,flashes about 10 times and quits,only after it has been driven and warmed up.?? battery going bad?
Volvo electronic expert
Online Data Transferring Service for Volvo modules
Angusthethird
Is the DIm in the alternator or on the firewall,or,as someone else said the CEM ? what does that stand for.Certain Ebay Moron?
Angusthethird
Thank you guys! would the DIM being bad also make reading the Outside Temp wrong also? which may effect the air conditioner? or is that the dreaded bad clutch assembly.?
crlande
- Year and Model: 240DL;850;S70
- Has thanked: 1 time
- Been thanked: 36 times
I had this issue once on my '94 850. I went under the drivers dash and found a bundle of wires that had worn thru a wrapping and the wire sheathing and the exposed wires were touching a steel cross member. Isolated and wrapped each exposed wire and all has been good since.
- yagger
Take a screenshot with errors from VIDA pls.Angusthethird wrote: 26 Mar 2020, 13:37 Thank you guys! would the DIM being bad also make reading the Outside Temp wrong also? which may effect the air conditioner? or is that the dreaded bad clutch assembly.?
- 1610 Views
Last post by wizechatmgr
- 1021 Views
Last post by 850oldschool
- 2063 Views
Last post by misha
- 10373 Views
Last post by FREEBUSINESSES
- 2820 Views
Last post by MoVolvos
