Did you know? 🤔
Quarter inch gap top strut bolt and washer
smacknab
Year and Model: 99 s70 NA Manual
Has thanked: 40 times
Been thanked: 8 times
United States of America
smacknab
Post by smacknab » Tue Mar 24, 2020 5:42 pm
Anyone know if this is normal? I didn't have the Volvo tool when I installed my sturts a couple weeks ago and I realized now this gap probably isn't normal. Can anyone confirm my suspicion (/suspension lol)?
Has thanked: 283 times
Been thanked: 893 times
Trinidad & Tobago
Re: Quarter inch gap top strut bolt and washer
Post by abscate » Tue Mar 24, 2020 6:37 pm
Looks like the cross nut isn’t down hard enough
See lots of discussion here
viewtopic.php?f=1&t=76848
These users thanked the author abscate for the post:
smacknab
Link To Volvo Glossary
smacknab
smacknab
Post by smacknab » Tue Mar 24, 2020 9:02 pm
Ah ok, interesting I figured it was just the top but. Thinking about the assembly.. do you think I have to put the car on jack stands and put the springs compressors on to get that nut down? Or can I just remove the top nut and washer with the car on the ground then just tighten from the top?
Has thanked: 90 times
Been thanked: 259 times
Post by erikv11 » Tue Mar 24, 2020 9:48 pm
Totally OK to remove it with the car on the ground.
You don't want to mess with it with the car in the air. The spring will decompress and shoot the strut downward. With the car on the ground the weight of the car compresses the spring, top is held by the fender bottom is held by the strut plate, it goes nowhere.
These users thanked the author erikv11 for the post:
smacknab
'96 855 NA, 145k
'98 V70, T5 tune-injectors-turbo, LPT engine, 285k
'06 S60 R, 165k
'99 Camry V6 :shock: 125k
smacknab
smacknab
Post by smacknab » Wed Mar 25, 2020 5:46 am
Thanks for the info!
Trinidad & Tobago
Post by abscate » Wed Mar 25, 2020 6:35 am
I’m missing something here.
If the cross nut is loose, you have to pull the strut and remove the strut bearing to get to it, don’t you?
Or can you just remove the nut and washer and get to it down the strut bearing hole?
jimmy57
Has thanked: 3 times
Been thanked: 230 times
jimmy57
Post by jimmy57 » Wed Mar 25, 2020 7:23 am
The cross nut is just under the rebound/unload bumper washer.
4-7 mm is normal on any I have replaced parts on. If you take wheels off straight ahead the gap grows on one side of the washer and decreases 180 degrees away as the strut moves eccentrically off center either direction.
Now for the tough part: you must counterhold the strut shaft while tightening or you have high risk of twisting the metal sleeve in the mount and possibly tearing it a little. That speeds failure. I often have wondered if the reports of using Lemforder or other brands with good track record and having short life span relates to this.
smacknab
smacknab
Post by smacknab » Wed Mar 25, 2020 8:02 am
So if I'm understanding what you're saying, you're also confirming I should keep wheels on and the car on the ground to do this? Holding the top has definitely been the tough part, I have a huge pipe wrench with teeth I was gonna try.
Looking at the assembly photo, and from my memory, the cross but goes through the strut washer so yeah should be a problem of needing to disassemble
Post by erikv11 » Wed Mar 25, 2020 2:36 pm
I've never done it but the last one.
The strut mount (bearing #3) just slips over the top it is not under tension. The cross nut (#8) tightens onto the sleeve in the spring seat (#7). When you remove a strut tower, the strut mount just lifts off the top, only fastener to be removed is the top nut (#1).
'96 855 NA, 145k
'06 S60 R, 165k
jimmy57
jimmy57
Post by jimmy57 » Wed Mar 25, 2020 3:09 pm
Keep wheels on ground and the spring is compressed. But if all you is tighten there is no risk. If you unscrew the cross nut other things could occur if car ride height is changed.
