So, let's have your opinions. The Shaggin' Wagon is giving me the occasional no-start. I know it isn't the battery since all dash lights light up like the proverbial Xmas tree. I turn the key and get lots of lights and no, and I mean zero sound. Last time this happened was about a week ago after a gas fill up. I rowed the shifter back and forth about 20 times rapidly and it restarted. The shift lock release button was incredibly difficult to depress.
Sound like a dirty/failed/failing PNP switch? Inquiring minds want to know.
'99 V70 FWD, Auto, Base, 235K miles -- Toasted PNP? Topic is solved
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
You can try jumping it with the under hood starter but be aware that the connector is upstream of the PnP
That would eliminate ignition switch , electrical part though. I have a spare one of those, by the way
- E Showell
I don't think the starter is dead since I'm pretty sure the original starter has been replaced (without removing the fan shroud) -- and for my next trick, I will be extracting the transmission through the rear tail gate . . . .
'95 855 auto (sold)
'95 855 auto (sold)
- Has thanked: 2200 times
what about the antenna ring. That inhibits the starter from running. Try cleaning the contacts to start with and check for cracking in the plastic casing causing breaks in the circuit.
I think the Shagging Wagon is a 99 with DENSO - Immobilizers inhibits starting but not cranking.scot850 wrote: 26 Mar 2020, 12:32 what about the antenna ring. That inhibits the starter from running. Try cleaning the contacts to start with and check for cracking in the plastic casing causing breaks in the circuit.
- E Showell
Steve -- Correct -- DENSO-equipped.
'95 855 auto (sold)
'95 855 auto (sold)
- misha
- Has thanked: 155 times
- Been thanked: 432 times
When it will not crank and start in "P"...start it in "N".
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- E Showell
Tough to depress the shift lock release button to move the shifter.
'95 855 auto (sold)
'95 855 auto (sold)
- misha
EU cars doesn't have that button.
Doesn't it suppose to override the gear selector?
It should not have anything to do with p'n'p switch.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- E Showell
Won't start in neutral. Not even turning over. Feels like no juice getting to starter, or bad starter.
'95 855 auto (sold)
'95 855 auto (sold)
- 17 Replies
- 3653 Views
- 690 Views
Last post by mayorpeoria
- 133 Views
Last post by misha
- 909 Views
Last post by oragex
- 204 Views
Last post by E Showell
