Battery charging question.
rguzz
- Year and Model: 1996 850 turbo
- Been thanked: 25 times
Silly question, does anyone see a problem using the bolt holding the blue cable in front of the battery as a chassis ground while charging the battery? It will function as my negative battery terminal, in other words.
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
That sounds like a good place to clip on. It should be a good ground point.
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Why avoiding the battery terminal?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- jreed
Some say to connect the ground wire to the body as the second connection to avoid creating a spark right at the battery, which could have hydrogen gas near it.
- misha
That's only in case if you need to jump start the car.
It's recommended....not necessary.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
rguzz
I'm actually trickle charging. Somehow, I feel more comfortable not using both battery posts for that purpose, but can't say about the science behind that thinking. BTW, okay to trickle charge leaving both battery cables connected, charger clip to the positive battery post, negative to the bolt on the chassis? Should be, right?
- misha
If you're charging the battery in the car with terminals connected....you need to remove the cell's caps on top of the battery.
When you finished with charging,allow battery to cool down for about 2 hours,replace the caps and you're done.
You can connect the charger directly on terminals,but make sure that you turn on and turn off the charger from power supply
BEFORE you connect and disconnect the charger clamps.
You can also do the charging in your way too.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
teyloradam
- Year and Model: 1998 nw 2015
- 7261 Views
Last post by JRL
- 3038 Views
Last post by dcarlson12
- 12 Replies
- 1688 Views
Last post by viper69
- 3206 Views
Last post by hyllus
- 21 Replies
- 4411 Views
Last post by bmdubya1198
