Did you know? 🤔
Battery charging question.
rguzz
Year and Model: 1996 850 turbo
Has thanked: 0
Been thanked: 5 times
rguzz
Post by rguzz » Thu Mar 26, 2020 3:16 pm
Silly question, does anyone see a problem using the bolt holding the blue cable in front of the battery as a chassis ground while charging the battery? It will function as my negative battery terminal, in other words.
jreed
Has thanked: 55 times
Been thanked: 34 times
United States of America
jreed
Re: Battery charging question.
Post by jreed » Thu Mar 26, 2020 3:51 pm
That sounds like a good place to clip on. It should be a good ground point.
misha
Has thanked: 54 times
Been thanked: 117 times
Serbia
misha
Post by misha » Thu Mar 26, 2020 4:05 pm
Why avoiding the battery terminal?
'91 Citroen XM 2.0 SI /fully equipped/mandarine red metallic
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
jreed
jreed
Post by jreed » Thu Mar 26, 2020 4:14 pm
Some say to connect the ground wire to the body as the second connection to avoid creating a spark right at the battery, which could have hydrogen gas near it.
misha
Serbia
misha
Post by misha » Thu Mar 26, 2020 4:27 pm
That's only in case if you need to jump start the car.
It's recommended....not necessary.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
rguzz
Has thanked: 0
rguzz
Post by rguzz » Thu Mar 26, 2020 5:12 pm
I'm actually trickle charging. Somehow, I feel more comfortable not using both battery posts for that purpose, but can't say about the science behind that thinking. BTW, okay to trickle charge leaving both battery cables connected, charger clip to the positive battery post, negative to the bolt on the chassis? Should be, right?
misha
Serbia
misha
Post by misha » Thu Mar 26, 2020 5:30 pm
If you're charging the battery in the car with terminals connected....you need to remove the cell's caps on top of the battery.
When you finished with charging,allow battery to cool down for about 2 hours,replace the caps and you're done.
You can connect the charger directly on terminals,but make sure that you turn on and turn off the charger from power supply
BEFORE you connect and disconnect the charger clamps.
You can also do the charging in your way too.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
