broken downpipe
dneu
- Year and Model: 2004 V70R
Contact dneu..
The downpipe on my 2004 V70R just broke off right from the flange connected to a turbo. Does anyone have any experience with welding it? I cannot find anywhere a reasonable replacement for less than $ 1200. Thanks.
- - Pete -
- Has thanked: 81 times
- Been thanked: 178 times
Wow, can you share a photo of it?
Did it break off AFTER the DP flange weld?
Is it the original DP?
If so, chances are it’s pretty crusty & you’d have an extremely hard time getting clean metal, and then it would also be unguaranteeable as far as the quality & longevity of the fix/weld.
These things get red hot.
I think you might be best off looking at an aftermarket DP. There are companies that make DP’s w/catalytic converters for under $500. No CEL for cat efficiency codes (downstream O2) and your turbo spools up quicker.
Snabb catted downpipe
RE-VOLV catted DP
I have 2 of those ^^^, one catless & one catted.
EuroSport Tuning Mototec DP
I’ll be installing one of these ^^^ today.
If you end up going with an aftermarket/larger diameter DP you will eventually want to get your ECM flashed for proper tune.
RE-VOLV catted DP
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
- ndphotonl
- Year and Model: 2001 S80 2.4T
- Has thanked: 27 times
- Been thanked: 33 times
Not needed, but you will reap the benefits more with a tune. I replaced the whole stock exhaust with stainless
BSR Tuning 3" downpipe with 200 cells cat + Rakaror 3" resonated catback.
BSR 3" Downpipe with Sports Catalyst by Andy Ramdin, on Flickr
Catalyst closeup
Volvo S80 2.4T 3" BSR Downpipe (Inside view) by Andy Ramdin, on Flickr
Old vs new, new downpipe comes with an extension cord for the secondary O2 sensor
Volvo S80 2.4T 3" BSR Downpipe by Andy Ramdin, on Flickr
Modded catback vs Rakaror 3" catback
Volvo S80 2.4T Rakaror 3" Stainless Resonated Catback by Andy Ramdin, on Flickr
How it sits under the car (I wanted to keep the stock look)
BSR 3" Downpipe with Sports Catalyst by Andy Ramdin, on FlickrCatalyst closeup
Volvo S80 2.4T 3" BSR Downpipe (Inside view) by Andy Ramdin, on FlickrOld vs new, new downpipe comes with an extension cord for the secondary O2 sensor
Volvo S80 2.4T 3" BSR Downpipe by Andy Ramdin, on FlickrModded catback vs Rakaror 3" catback
Volvo S80 2.4T Rakaror 3" Stainless Resonated Catback by Andy Ramdin, on FlickrHow it sits under the car (I wanted to keep the stock look)
Volvo S80 2.4T Rakaror 3" Stainless Resonated Catback by Andy Ramdin, on FlickrVolvo S80 2.4T Wasa Limited Edition (+-230-240BHP)
FlickR images
FlickR images
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Welding is very difficult because it's rotten and because it must keep the flange angle or the flexible will be under stress and fail soon after. Clearly a job for a very skilled exhaust place. But as above, there's aftermarket options, search on Ebay, however some may throw a check engine (cheap cat), may fit poorly (this will also quickly cause the flexible to leak) and also if you have emission inspections I don't think cheap ones will pass
