turn signal not self cancelling fix
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
darrylrobert
Year and Model: 2001 v70xc M58
Been thanked: 27 times
Post by darrylrobert »
Another annoying item on my 19yr old xc70 was the turn signal not self cancelling on the right indicator. I removed the old indicator stalk and tested it in a spare steering module. The cancelling point had moved from 12 o'clock position to about 2 o'clock (see pic) , not sure if its wear as the little tab/tounge didnt look damaged or worn. Installed the spare stalk and fixed the problem now both left and right cancel around 12 o'clock.
No programming was needed all the fuctions of the stalk work. Its plug and play, hope this helps anyone with the same issue.
1981 260 GLE converted to 240 M46 after auto box failure
1987 740t auto converted to M47
1997 V70t5 auto converted to M56
1998 V70 factory M56 (parts car)
2001 XC70 factory M58
2002 XC70 auto (parts car)
Has thanked: 1507 times
Been thanked: 3824 times
Thanks for fixing them, and even more importantly , wearing them out
Good sarcastic PSA for indicating
crlande
Year and Model: 240DL;850;S70
Has thanked: 1 time
Been thanked: 36 times
Post by crlande »
Funny. Should have also mentioned to use it well in advance of your intention and nor does it give you the right to merge into traffic just because you had it on!
