ABS, DTSC module resofting after replacement
wanderdüne
- Year and Model: 2004, 2006 XC90 2.5T
- Has thanked: 6 times
- Been thanked: 45 times
I do not think that you can program with Volvo software a replacement module unless it is a new part from Volvo. If it is a new module, you can download the software from Volvo and install using VIDA/DiCE. Otherwise, if you still have your old module, perhaps you can find help here: https://xemodex.com/us/diagnostic-flow-charts/ This is a trusted source.bogdanp wrote: 30 Mar 2020, 11:40 My ABS, DTSC module has been changed and I've been instructed that it needs to be resofted. Anyone has the possibility to do it remotely?
I know with DTSC, the only thing xeMODex can do is repair and return to you your old module, which is programmed to your XC90.
Note that xeMODex does remote diagnostics, including internationally. Click on the REMOTE DIAGNOSTICS tab for information. This is not programming, though.
Also, look under TECHNICAL RESOURCES at the flow charts that pertain to your XC90 and see if that helps.
- yagger
- Year and Model: V60 2016
- Been thanked: 39 times
Also, one additional question, do we talk about car from your profile? (Year and Model: XC90 2007)
Volvo electronic expert
Online Data Transferring Service for Volvo modules
- 527 Views
Last post by volvooh
- 479 Views
Last post by - Pete -
- 1983 Views
Last post by jaylwood5000
- 716 Views
Last post by warcraftjunkie
- 1696 Views
Last post by RickHaleParker
