Did you know? 🤔
Parting out 2011 C30 124k miles white
Rvolvos
Year and Model: 2006 xc70
Has thanked: 34 times
Been thanked: 3 times
United States of America
Rvolvos
Post by Rvolvos » Mon Mar 30, 2020 12:33 pm
he car is completely disassembled and will be picked up this week.
All the parts removed are for sale, price indication 1/4-1/2 of pick-n-pull prices
Car is located in Livermore California
LH fender
Rh door
Mirrors left and right
Dash pad with passenger airbag
Dash vents
Door cards
Waterfall assembly
Bluetooth module
Rear door speakers
Amplifier
Radio , CD player
Display
Gauge Frame Bezel
Engine, see link for pictures and YouTube video of engine running; viewtopic.php?f=6&t=91986
Automatic transmission
Heater core
Ac condensor
Hvac unit complete
Steering with buttons
Steering wheel module
Steering angle sensor
Left and right stalks
Glovebox
Seat belts front and rear
Driver side headlight
Ac compressor
Trunk lock
Window motor driver side
Sirius receiver & shark fin with antenna amplifier.
Handbrake lever
Mid console
Steering rack with subframe
Stock springs front and rear
Fuel door, fuel door lock
Shifter cable
RH front knuckle 66k miles
Window washer bottle with motor
Radiator, radiator fan
Stock down pipe CA certified
Stock exhaust
Right rear trailing arm, chamber arm, toe link
Sway bar with links
Spare tire
Lug nuts
Charcoal canister with evap pump
Inter cooler and piping
Stock air-intake
Battery
Wiper motor assembly
Sunroof assembly
Dome light assembly with sunroof controls
A trim pillars beige
Front calipers 66k miles
Rear calipers
Brake Master cilinder
Brake booster
ABS pump.
CEM, ECU(+polestar tune) Display, ABS module and one key can be bought as one set.
Rear crush bar
Rear bumper attachment bracket center and rh
Rh rocker black
Pem
Sun visors
Rear view mirror
Battery box, no cover
Maf sensor
02 sensors front and rear
Brake switch
Throttle pedal
Park brake switch
Light sensor dash
Abs sensors
Hood lever
Yaw rte sensor
Let me know what you need and make pictures and check part numbers
2006 XC70 2.5T 190k
2006 V70 2.5T 152k
2011 C30 T5 AW55-50SN 99k
2011 C30 T5 M66 66k
