You will often find voltage at the load side of a disconnected fuse because of cross feed from loads with ballast resistors , diodes, etc on other circuits. If the fuse is blowing, you have a short or a failed component.
Disconnect the component and that leaves the wiring.
Often shorts are intermittent and so ohm testing won’t show them, the left rear pillar wiring is a classic example
'00 V70 FWD: Fuse 27 keeps blowing - reverse lights / turn signal Topic is solved
- Has thanked: 479 times
- Been thanked: 1413 times
Re: '00 V70 FWD: Fuse 27 keeps blowing - reverse lights / turn signal
1999-V70-T5M56 2005-V70-M56 1999-S70 VW T4 BMW
- Year and Model: V70, 2000
- Has thanked: 6 times
Ok everyone - thanks for all of the advice! I removed the reverse light bulbs, disconnected the PNP wiring harness and tested pin 5 (to reverse lights) to ground - no reading (OL) - no continuity - so no short in the wires between the PNP and rear lights. That left the PNP itself. Got one from FCP - it arrived this afternoon and I put it in - everything is back to normal! I'm glad I opted for ordering a new one, because the old one that came off didn't have the screws on the back to take it apart... There were 3 different part numbers that all say they fit on my 2000 V70 N/A, I ordered the cheaper one (still genuine volvo) which was PN 9495007 - it said only for Aisin Warner AW55-50SN/51SN transmissions. That one was $123, the other two were $181. Worked perfect. Special thanks to BEJinFbk, abscate and SuperHerman - all of your help is much appreciated!
Great news, and Godspeed getting through the next week.
- 1054 Views
Last post by SuperHerman
- 1261 Views
Last post by nthnnxn
- 1186 Views
Last post by doublebug
- 979 Views
Last post by RickHaleParker
- 18 Replies
- 1300 Views
