Did you know? 🤔
Mystery Transmission Line- 2007 S80 3.2 Topic is solved
Help, Advice, Owners' Discussion and DIY Tutorials on the third generation Volvo V70 wagon and XC70 crossover, and second generation S80. Are you an owner? Prospective owner? Get in here and join us! Start a new topic or comment on an existing thread.
2008-2016 V70
2008-2016 XC70
2007-2016 S80
Skymongrel
Year and Model: XC70 2006, S80 2007
Has thanked: 11 times
United States of America
Skymongrel
Post by Skymongrel » Tue Mar 31, 2020 4:25 pm
This post is in reference to my recently acquired 2007 S80 3.2 6 Cyl. (121K).
I discovered an oil leak of some sort along the side of my transmission at the driver side wheel well. I can spot a plastic tube going into the side of the transmission where the leak seems to be coming from. I can't get to it without removing a lot of stuff up top; air box, battery and battery box. So before I expose it completely I need to know what this part is and how to fix it. I'm assuming maybe its just an o-ring that needs to be changed. Or maybe I'm seeing that the tube isn't well seated from my pictures and a gently nudge might do the trick!
These pictures are all shot with the driver's wheel removed and looking towards the front of the car from behind the LH axel. Any help identifying this tube would be most helpful!
Plastic tube with loose circular clip, picture taking from drivers wheel well
Plastic tube close-up, maybe not seated, circular clip removed
Another view
Another view
Reason: Edited title. Please, no "HELP"s in Subject titles.
Skymongrel
Skymongrel
Re: Mystery Transmission Line- Help!  Topic is solved
Post by Skymongrel » Thu Apr 02, 2020 8:30 am
I removed the airbox and battery box to get a look at the line/tube/hose in question. I appears to be a vent line. It is about six inches long with a vent cap on it and terminates at the base of the battery box. I could see no way to easily remove the fitting that mates with the transmission to address the leak. I reattached the loose clip and repositioned the line and will monitor.
Here are some terrible pictures
Looking down from battery box area six inch tube
Vent Cap and Clip
pgill
Year and Model: 2010 S80, 2008 LR2
Has thanked: 23 times
Been thanked: 42 times
pgill
Re: Mystery Transmission Line- 2007 S80 3.2
Post by pgill » Fri Apr 10, 2020 11:00 pm
Take a look at this eBay transmission for pictures of the breather tube
https://www.ebay.com/p/18018998398?iid= ... BsQAvD_BwE
Good luck
Paul
These users thanked the author pgill for the post:
Skymongrel
Skymongrel
Skymongrel
Post by Skymongrel » Mon Apr 13, 2020 5:58 pm
Yes! That's the one! What a good picture. Thanks. Now....how is that tube removed? Just a press fit with o-rings? Mine is still weeping and of course it looks like I'm losing more than I am.
pgill
pgill
Post by pgill » Mon May 18, 2020 4:42 pm
I looked to see if I could find this vent from another source (i.e. Aisin, Mazda, Ford, Land Rover, etc.)
All I found was information that indicates its a press fit.
The Vendors that rebuild Transmissions must have a solution but I couldn't find it.
Let us know what you find out.
Thanks
Paul
