2006 Volvo XC90 2.5T AWD
Started out as replacing the thermostat and engine coolant sensor - discovered I cannot (at least pretty sure I can't) replace the engine coolant sensor without removing the "lower body" on the thermostat housing and to get at the "lower housing" I will need to remove the power steering pump which when I looked closer actually has a pretty good leak - so now I'm going to do both - thermostat and PS pump.
Watched/read a bunch of stuff online and it doesn't seem too bad, I'm just at a loss as to what tool I will need to loosen the tension on the power steering pump belt to eventually remove it. Do I need to buy a specific tool or can I use something common?
Thank you in advance!
What tool do I need to remove power steering pump belt - 06 XC90 2.5T
- RickHaleParker
- Been thanked: 978 times
T60 Torx bit and a long ratchet.bfry wrote: 01 Apr 2020, 21:06 I'm just at a loss as to what tool I will need to loosen the tension on the power steering pump belt to eventually remove it. Do I need to buy a specific tool or can I use something common?
If you need more room on the top and have the ECM tool. You can remove the top cover and sides of the ECM box. Then remove the ECM and TCM. If you do this make sure the negative battery cable is disconnected before pulling the ECM and TCM. When reconnecting battery, first turn key to POS II then reconnect battery. Reconnect battery after reinstalling ECM and TCM.
Active
Past
Past
wanderdüne
- Year and Model: 2004, 2006 XC90 2.5T
- Has thanked: 6 times
- Been thanked: 45 times
I got this one: https://www.ebay.com/itm/Volvo-Idler-Wr ... 2749.l2649
It's "pretty good" quality. KTC-VOL1268
- RickHaleParker
For $13.95 one could get a 13 pcs set of Torx security bits with sizes up to T60.wanderdüne wrote: 02 Apr 2020, 10:10 I got this one: https://www.ebay.com/itm/Volvo-Idler-Wr ... 2749.l2649
For $32.95 one could could get a 3 pcs Extendable Ratchet set.
$13.95 + $32.95 = $46.90.
$46.90 - $34.99 = $11.91.
For $11.91 more one could get some tools will do the job the specialized tool does and a lot more.
Active
Past
Past
wanderdüne
But I have a jobRickHaleParker wrote: 02 Apr 2020, 12:42For $13.95 one could get a 13 pcs set of Torx security bits with sizes up to T60.wanderdüne wrote: 02 Apr 2020, 10:10 I got this one: https://www.ebay.com/itm/Volvo-Idler-Wr ... 2749.l2649
- 4756 Views
Last post by sventastic
- 7038 Views
Last post by SuperHerman
- 1640 Views
Last post by eheffel
- 5776 Views
Last post by Turbo_Boss
- 4120 Views
Last post by wanderdüne
