Did you know? 🤔
What tool do I need to remove power steering pump belt - 06 XC90 2.5T
Help, Advice, Owners' Discussion and DIY Tutorials on Volvo XC90s. The XC90 proved to be very popular, and very good for Volvo's sales numbers, since its introduction in model year 2003 (North America).
bfry
Year and Model: 2006 XC90 2.5T AWD
Has thanked: 19 times
Been thanked: 0
United States of America
bfry
Post by bfry » Wed Apr 01, 2020 9:06 pm
2006 Volvo XC90 2.5T AWD
Started out as replacing the thermostat and engine coolant sensor - discovered I cannot (at least pretty sure I can't) replace the engine coolant sensor without removing the "lower body" on the thermostat housing and to get at the "lower housing" I will need to remove the power steering pump which when I looked closer actually has a pretty good leak - so now I'm going to do both - thermostat and PS pump.
Watched/read a bunch of stuff online and it doesn't seem too bad, I'm just at a loss as to what tool I will need to loosen the tension on the power steering pump belt to eventually remove it. Do I need to buy a specific tool or can I use something common?
Thank you in advance!
RickHaleParker
Has thanked: 3 times
Been thanked: 540 times
RickHaleParker
Re: What tool do I need to remove power steering pump belt - 06 XC90 2.5T
Post by RickHaleParker » Thu Apr 02, 2020 12:13 am
bfry wrote: ↑
T60 Torx bit and a long ratchet.
If you need more room on the top and have the ECM tool. You can remove the top cover and sides of the ECM box. Then remove the ECM and TCM. If you do this make sure the negative battery cable is disconnected before pulling the ECM and TCM. When reconnecting battery, first turn key to POS II then reconnect battery. Reconnect battery after reinstalling ECM and TCM.
These users thanked the author RickHaleParker for the post:
bfry
Platform: P80 1998 C70, B5234T3, 16T, AW50-42, Bosch Motronic 4.4, Special Edition package, Plant: Uddevalla Sweden.
Platform: X40 (Nedcar) 2003 S40, B4204T3, 14T twin scroll AW55-50/51SN, Siemens EMS 2000. Plant: Born Netherlands.
Platform P2 2005 XC90 T6 Executive, B6294T, 4T65 AWD, Bosch Motronic 7.0, Plant Torslanda Sweden.
Platform P2 2004 S60R, B2524T4, AW50/51 AWD, Bosch Motronic 7.0, BorgWarner K24 turbocharger, Plant Ghent Belgium.
wanderdüne
Year and Model: 2004, 2006 XC90 2.5T
Has thanked: 4 times
Been thanked: 38 times
wanderdüne
Post by wanderdüne » Thu Apr 02, 2020 10:10 am
I got this one: https://www.ebay.com/itm/Volvo-Idler-Wr ... 2749.l2649
It's "pretty good" quality. KTC-VOL1268
These users thanked the author wanderdüne for the post:
bfry
bfry
Been thanked: 0
bfry
Post by bfry » Thu Apr 02, 2020 12:19 pm
Awesome - thank you guys!
RickHaleParker
RickHaleParker
Post by RickHaleParker » Thu Apr 02, 2020 12:42 pm
wanderdüne wrote: ↑
For $13.95 one could get a 13 pcs set of Torx security bits with sizes up to T60.
For $32.95 one could could get a 3 pcs Extendable Ratchet set.
$13.95 + $32.95 = $46.90.
$46.90 - $34.99 = $11.91.
For $11.91 more one could get some tools will do the job the specialized tool does and a lot more.
wanderdüne
wanderdüne
Post by wanderdüne » Thu Apr 02, 2020 2:33 pm
RickHaleParker wrote: ↑
wanderdüne wrote: ↑
But I have a job :) And several Volvo's in the family. Not sure why I'd want to buy marginal tools to fumble around with the job when I can buy a purpose-built tool that works great and without interference for the 3 different styles of Volvo tensioners.
