Did you know? 🤔
2004 S60R B8444S (V8) conversion (Previously : Exhaust Manifold removal.)
2001 - 2007 XC-70
jonesg
Year and Model: 2004 V70
Has thanked: 2 times
Been thanked: 24 times
Wales
jonesg
Re: 2004 S60R B8444S (V8) conversion (Previously : Exhaust Manifold removal.)
Post by jonesg » Sat Jun 20, 2020 8:26 am
I agonize whether to install a cigarette lighter.
RickHaleParker
Has thanked: 3 times
Been thanked: 556 times
United States of America
RickHaleParker
Post by RickHaleParker » Sat Jun 20, 2020 8:49 pm
Bolted in:
Platform: P80 1998 C70, B5234T3, 16T, AW50-42, Bosch Motronic 4.4, Special Edition package.
Platform: X40 (Nedcar) 2003 S40, B4204T3, 14T twin scroll AW55-50/51SN, Siemens EMS 2000.
Platform P2 2005 XC90 T6 Executive, B6294T, 4T65 AWD, Bosch Motronic 7.0.
Platform P2 2004 S60R, B2524T4, AW50/51 AWD, B8444S TF80 AWD, Bosch Motronic 7.0, BorgWarner K24 turbocharger. V8 conversion in progress.
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 44 times
Been thanked: 158 times
bmdubya1198
Post by bmdubya1198 » Sun Jun 21, 2020 8:44 am
Exciting! This is where the fun starts.
2000 V70R Venetian Red/Charcoal M56 Swapped 197k
2003 S60 2.4T Silver/Black 113k
2007 XC90 V8 AWD Sport Titanium Grey/Black 171k
1991 944 Turbo Dark Green/Beige 174k
1992 245 Base White/Beige 249k
2006 BMW 330i
1999 BMW 528i
2000 S70 GLT Mystic Silver/Taupe 253k
1993 944 Base Beige/Beige 221k
1998 V70 GLT Black/Beige 199k
1998 S90- Silver/Gray 207k
1995 850 GLT Tropic Green... crushed
2001 S60 2.4T Black/Black 230k
1988 744 Turbo M46 Beige Metallic/Beige 188k
RickHaleParker
RickHaleParker
Post by RickHaleParker » Mon Jun 22, 2020 8:08 pm
I am using the hard A/C lines from the XC90. The XC90 has two Evaporators. The S60 has only one. I cut off the excess lines figuring I could braze some Aluminum end caps on like I did decades ago. Looked high and low for the end caps. It is like they been vanished from existence. Any alternative ideas or sources for Aluminum end caps?
Small tube is 9.5mm (3/8") Dia. Large tube is 16MM (5/8") Dia.
RickHaleParker
RickHaleParker
Post by RickHaleParker » Wed Jun 24, 2020 9:23 pm
Is it like the Paper or Plastic decision ... Electric or Butane?
Year and Model: 2001 V70
Has thanked: 35 times
Been thanked: 75 times
Post by volvolugnut » Thu Jun 25, 2020 1:21 pm
Machine your own end caps from Aluminum bar stock. Easy for anyone with a lathe, even a hobby lathe.
2001 V70 T5, 1986 244DL, 1983 245DL, 1975 245DL, 1959 PV544, multiple parts cars.
RickHaleParker
RickHaleParker
Post by RickHaleParker » Thu Jun 25, 2020 3:56 pm
I do not have a lathe not even a hobby lathe.
On the small one I found a socket cap screw that self threaded into the tube. However it is steel. I never brazed aluminum to steel so I do not know if that will work out. Thinking about sealing it with Loctite red. Then see if a can find the right size bolt to do the larger one.
Post by volvolugnut » Thu Jun 25, 2020 5:11 pm
How about this cap from McMaster Carr?
RickHaleParker
RickHaleParker
Post by RickHaleParker » Thu Jun 25, 2020 6:28 pm
Those are Copper. Copper - Aluminum junctions are highly susceptible to Galvanic corrosion. That green stuff that grows near the soldered joints of Copper water pipes.
RickHaleParker
RickHaleParker
Post by RickHaleParker » Thu Jun 25, 2020 6:39 pm
Options:
  • 1. Roll the dice with Loctite red.
    2. Roll the dice with aluminum brazing on Aluminum- Steel.
    3. Abandon the whole idea.
