Did you know? 🤔
2004 S60R B8444S (V8) conversion (Previously : Exhaust Manifold removal.)
2001 - 2007 XC-70
RickHaleParker
Has thanked: 3 times
Been thanked: 562 times
United States of America
RickHaleParker
Re: 2004 S60R B8444S (V8) conversion (Previously : Exhaust Manifold removal.)
Post by RickHaleParker » Sat Jun 27, 2020 3:31 pm
yagger wrote:
Sat Jun 27, 2020 2:59 pm
2006 XC90 VIN: YV4CZ852761299806 - best choice I think.
That is the donor for the ECM and TCM. The CEM out if that would is already sync with the ECM. Don't know if I can get the key transponder. Will simplify thing if I can.
Platform: P80 1998 C70, B5234T3, 16T, AW50-42, Bosch Motronic 4.4, Special Edition package.
Platform: X40 (Nedcar) 2003 S40, B4204T3, 14T twin scroll AW55-50/51SN, Siemens EMS 2000.
Platform P2 2005 XC90 T6 Executive, B6294T, 4T65 AWD, Bosch Motronic 7.0.
Platform P2 2004 S60R, B2524T4, AW50/51 AWD, B8444S TF80 AWD, Bosch Motronic 7.0, BorgWarner K24 turbocharger. V8 conversion in progress.
yagger
Year and Model: S60 2005 2,5T
Has thanked: 5 times
Been thanked: 25 times
Belarus
yagger
Post by yagger » Sat Jun 27, 2020 3:54 pm
I can program key.
Volvo electronics and programming.Yagger&Doublebug - our experience invaluable.
Aftermarket Online Data Transferring Service for Volvo Pass: total
RickHaleParker
RickHaleParker
Post by RickHaleParker » Sat Jun 27, 2020 4:03 pm
I can program key.
How about new remotes when I have the encryption keys for the remotes?
I don't have them right now but I know where I can get everything, blade, case, transponder, remote and remote encryption keys for $60.00 a pair.
I have a local locksmith that can cut the blade but cannot do the programing.
RickHaleParker
RickHaleParker
Post by RickHaleParker » Sun Jun 28, 2020 11:48 am
Got the Air / ECM box all prettied up and it does not fix. Sits too tall. Thinking of modding the box so it hangs over the frame.
yagger
Belarus
yagger
Post by yagger » Sun Jun 28, 2020 12:35 pm
Yes, we can program remote too.
Year and Model: 2001 V70
Has thanked: 37 times
Been thanked: 78 times
Post by volvolugnut » Sun Jun 28, 2020 1:02 pm
You could get a hood scoop like this:
2001 V70 T5, 1986 244DL, 1983 245DL, 1975 245DL, 1959 PV544, multiple parts cars.
RickHaleParker
RickHaleParker
Post by RickHaleParker » Sun Jun 28, 2020 5:53 pm
Did the measurements, It is 2" too high. I am pretty sure I can mod the box if I can find plate plastic to weld in place.
Na that is for a longitudinal engine.
If I was going to go the scoop route, let it be something more like this.
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 45 times
Been thanked: 160 times
bmdubya1198
Post by bmdubya1198 » Sun Jun 28, 2020 8:03 pm
Go Z31 style
You could probably make something fairly easily to make that air box sit lower.
2000 V70R Venetian Red/Charcoal M56 Swapped 197k
2003 S60 2.4T Silver/Black 113k
2007 XC90 V8 AWD Sport Titanium Grey/Black 171k
1991 944 Turbo Dark Green/Beige 174k
1992 245 Base White/Beige 249k
2006 BMW 330i
1999 BMW 528i
2000 S70 GLT Mystic Silver/Taupe 253k
1993 944 Base Beige/Beige 221k
1998 V70 GLT Black/Beige 199k
1998 S90- Silver/Gray 207k
1995 850 GLT Tropic Green... crushed
2001 S60 2.4T Black/Black 230k
1988 744 Turbo M46 Beige Metallic/Beige 188k
RickHaleParker
RickHaleParker
Post by RickHaleParker » Sun Jun 28, 2020 9:33 pm
It is 2" too high sitting on the frame. I thought about cutting a notch on the outside so it would drop 2" but it look like I may not have 2" of clearance above the transmission cable.
ECM wiring harness on the engine side is short and does not give much if any option for relocating the ECM. besides the ECM is mounted on top of the Air box to keep it cool. Heat sink fins are in the air flow.
I might be looking at a custom air box, low but spread out. Maybe do it original hot rod style, rummage around the junk yard until I find a low profile that will do the job. Don't want to go with a small filter, to insure the engine does not asphyxiate.
The MAF housing is molded into the box also. The MAF sensor need to be in a air flow with the same cross section.
Post by volvolugnut » Mon Jun 29, 2020 12:44 pm
I doubt you have room to move it, but don't get hung on the air box must orient as it is now. The air would not care if you turned it sideways.
