Anyone ever replace the carrier bearings on CV axles?
Richard99
Year and Model: 2000 V70XC
Has thanked: 26 times
Been thanked: 23 times
Post by Richard99 »
Has anyone ever replaced the carrier bearings on CV axles? If so, how'd you do it? I am suspicious they are shot and making some noise on my 2000 V70XC and I believe these are an often overlooked item.
Eric
Eric
1998 Volvo V70 - rear-ended and totaled
2000 Volvo V70XC
2007 Volvo V50 T5 AWD M66
FlyingVolvo
Has thanked: 51 times
Been thanked: 74 times
Post by FlyingVolvo »
There's only one on the passenger side axle Easiest thing to do would just be get under there, unbolt the two (12mm I think) bolts on the holder, and spin it and see if it's good. Honestly, I kinda doubt that would be the source of any major noise, but this car still surprises me sometimes.
What kinda noise are you experiencing?
2000 V70XC - 340,000 miles
2023 V60 T8 PE
Richard99
Post by Richard99 »
I'm experiencing a constant whine noise. It's a higher pitch than what I had with a bad wheel bearing with my 98'. I'm thinking it's probably coming from my angle gear but not sure. Second guesses would be a wheel bearing or carrier bearing.
I've sort of gotten started on an angle gear rebuild which I got from another car. I'm hoping to weld it to the angle gear splines like others have done. Also not sure how difficult it will be to replace the bearing and seals on it.
Eric
Eric
2000 Volvo V70XC
wizechatmgr
Has thanked: 45 times
Been thanked: 128 times
Post by wizechatmgr »
Richard99 wrote: 03 Apr 2020, 21:48 I'm experiencing a constant whine noise. It's a higher pitch than what I had with a bad wheel bearing with my 98'. I'm thinking it's probably coming from my angle gear but not sure. Second guesses would be a wheel bearing or carrier bearing.
Eric
When did you last service the angle gear?
Richard99
Post by Richard99 »
I bought the car with 120k miles and changed the fluid shortly thereafter.
Eric
2000 Volvo V70XC
wizechatmgr
Richard99 wrote: 03 Apr 2020, 22:30 I bought the car with 120k miles and changed the fluid shortly thereafter.
How many miles now? Mine started whining ~140-150k and I flushed the living crap out of it and it became tolerable. I'm at ~188k miles at this point. I know I need to do it again or get prepared to rebuild a donor.
Richard99
Post by Richard99 »
Just shy of 125k miles now. I'm planning on rebuilding a donor right now. I will document my experience and share what happens.
Eric
2000 Volvo V70XC
Has thanked: 2199 times
Been thanked: 1852 times
I have had 2 axles with bad carrier bearings. Removing then is a challenge. Volvo does not really do this anymore and there is no bearing listed by Volvo as a replacement sealed bearing for the 99-00 carrier bearings. The one for a 98 is still listed and is the same part. I tracked down bearings in Turkey following a lead from abscate. They were for a Ford Transit if I recall.
The local dealer managed to remove the bearing. I fitted the new one using a length of metal fence post that was the same diameter as that of the bearing.
To remove the bearing I have read of people breaking the bearing off by splitting it.
Richard99
Post by Richard99 »
Thanks, Neil. If I discover that the carrier bearing is bad, I was planning on cutting it off with a dremel, tedious as that may be. I will try to track down a new bearing if I find that my bearing is bad.
Eric
2000 Volvo V70XC
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
Maybe do most of the cutting with an angle grinder instead?
