I have a 2007 C30 T5 with codes P0497 and P0443.
I want to change the evap canister purge valve, but I can't find it.
I haven't been able to find anything on the web. Pics would be nice.
2007 C30 T5 purge valve location
cdnbluez
- Year and Model: 09 C30/98 V70/99 S70
- Been thanked: 3 times
2007 C30 T5 6 Speed
2005 S40
2006 XC70
2014 Mercedes E350
1996 Corvette Convertible LT4
Previous Volvos:'09 C30 5 speed, '99 S70, '99 S70 5speed, '98 V70 SE, '04 XC70, '01 V70, '02 V70 awd, '97 855, '90 745 Turbo+, '90 745 16v, '89 780 Bertone Turbo+, '86 760 Turbo+, '82 240 GL
2005 S40
2006 XC70
2014 Mercedes E350
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
Good place to start or search the 2.4L.
https://www.volvopartswebstore.com/cars ... parts.html
cdnbluez
Thanks BKM,
unfortunately the diagram on volvopartswebstore doesn't show where the purge valve is located on the engine, it shows all the parts that connect to the purge valve. It used to be sooo easy to locate, usually on the fan shroud. I have heard its on the drivers side at the back of the engine.
2007 C30 T5 6 Speed
2005 S40
2006 XC70
2014 Mercedes E350
2005 S40
2006 XC70
2014 Mercedes E350
cdnbluez
I found it on pelicanparts.com, ignore the colored arrows.
Its the part with the yellow markings on the right side of the pic. It shows part number 8653909 which is the purge valve.
I hope this helps other looking for the purge valve.
2007 C30 T5 6 Speed
2005 S40
2006 XC70
2014 Mercedes E350
2005 S40
2006 XC70
2014 Mercedes E350
- 12790 Views
Last post by stavri
- 3722 Views
Last post by XC90V8Pearl
- 2177 Views
Last post by sleddriver
- 10494 Views
Last post by SuperHerman
- 11 Replies
- 3036 Views
Last post by volvomadness
