2012 S60 Rear Brake Wheel Bearing Hub Topic is solved
cuhfs
- Year and Model: 850,XC70,XC90,S60,80
- Has thanked: 17 times
- Been thanked: 31 times
All - does anyone have a write-up / tutorial for replacing the rear wheel bearing hub on a 2012 S60. I have a clicking noise and am making the leap that with 157,000 miles it is likely a wheel bearing. Any help and tips is appreciated.
04 C70 Convert Auto
06 XC90 Auto (ORE) #401/800
06 S80
05 S80
12 S60
04 XC70 Auto (Parts car)
96 850 Wagon Manual Trans & 98 V70 (gone)
95 850 Sedan Auto Trans (gone)
04 XC70 Auto (gone)
04 C70 Convert (gone)
01 C70 Convert Manual Trans (gone)
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
cuhfs
Job done. This is a FWD so no rear axle to deal with. Removed caliper and rotor... then its 4 bolts so you need T50 or T55 (I dont recall), unplug speed sensor. R&R. I used wobble extensions to get to the Torx bolts. All bolts were very hard to break open. Maybe next time I'll let'em soak in penetrating oil overnight. Similar to the older Volvos except for the bolts were Torx and the electric caliper.
04 C70 Convert Auto
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
- 2455 Views
Last post by [email protected]
- 1970 Views
Last post by sleddriver
- 13 Replies
- 2655 Views
- 1117 Views
Last post by XCfella
- 991 Views
Last post by greekbuckeye
