Installed a set of control arms from 1A Auto. Increased the length of the adjustable control arm to reduce negative camber. Will do a full DYI alignment another day.
https://www.1aauto.com/products/i/1ASFK ... nfirmation
Mazda seems to have a bit more room to work with. She makes it look easy.
Do Not Follow 1A Auto's Video. Follow these 2 video as the control arms are torqued after the car has been lowered to normal ride height. If you tighten it in the air when the suspension is unloaded it will be pre-loaded / stressed in the normal resting position of the car.
08 C30 T5 Rear Adjustable Camber Arm
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
