Wheel bearing dust cap info
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Between the outer CV joint and the wheel hubs there is this little plastic cap. It actually keeps dirt from getting at the wheel bearing - the bearing is sealed but if this dust seal is missing, the bearing will wear prematurely (not a fun job). I believe it goes with the larger side on the CV joint - it should fit tight over the side of the CV joint any way, not loose.
https://www.fcpeuro.com/products/volvo- ... 15#reviews
