Did you know? 🤔
no boost in 05 xc70
2001 - 2007 XC-70
Clockboy
Year and Model: 05 xc70, v70 2.5t 06
Has thanked: 2 times
United States of America
Clockboy
no boost in 05 xc70
Post by Clockboy » Fri Apr 10, 2020 10:27 am
I just did the timing belt and pcv system on my wife's 05 xc70. In doing so I cleaned the throttle body and replaced the gasket. The car started, but it had a rolling idle almost stalling out. It threw a throttle code. I started it again and it was idling fine, but now is not boosting. Just sounds like a bad exhaust system with no power when accelerating and expecting the boost.. Normal driving sounds fine. Is it possible the throttle body still needs to be adapted to the system and that is why there is no turbo boost or is it more likely a vacuum leak or exhaust constriction? Still have to look at everything closer, but wanted to perhaps eliminate the throttle body.
SuperHerman
Has thanked: 0
Been thanked: 157 times
SuperHerman
Re: no boost in 05 xc70
Post by SuperHerman » Sat Apr 11, 2020 2:10 pm
First thing you need to do is check all your hoses. Good chance one was dislodged and/or incorrectly placed in the wrong spot. Always check your work if you have a problem as well as any thing nearby.
Next check your vacuum hoses - starting at the turbo and going to the boost control solenoid where it should then branch off with two more hoses if I recall. Many times the hose at the turbo has disintegrated and is the cause of the problem.
darrylrobert
Year and Model: 2001 v70xc
Has thanked: 3 times
Been thanked: 7 times
Australia
darrylrobert
Post by darrylrobert » Sun Apr 12, 2020 2:42 am
From personal experience i avoid doing multiple repairs at the same time. You need to backtrack and check all your work.
shiloh51933
Has thanked: 11 times
Been thanked: 10 times
shiloh51933
Post by shiloh51933 » Sun Apr 12, 2020 9:45 am
Even when you disconnect the battery the learning curve for the ECM/Network is extremely quick...regardless she should still have boost. If you have a DTC for the ETM the you need to retrace your steps in that area. Is there any messages on the cluster screen?
If U Wanna Play U Gotta Pay!!
Has thanked: 317 times
Been thanked: 982 times
Trinidad & Tobago
Post by abscate » Sun Apr 12, 2020 7:41 pm
The throttle body’s on P2s is pretty reliable. Almost any code from engine management side will inhibit boost. Its a vacuum line or electrical disconnect somewhere.
Link To Volvo Glossary
Clockboy
Clockboy
Post by Clockboy » Fri Apr 24, 2020 2:13 pm
I went back and took a look at everything. When I looked at the intake pipe for the throttle body it was sort of on. Gave it a little tap and it fell off. Then I remembered putting the parts back together sort of out of sequence and having to reach and curse my way to getting it on. Obviously I did not say the right curses because it was not on. It is now and there is plenty of boost. Induction, induction, induction. Thanks to all.
- Pete -
Has thanked: 55 times
Been thanked: 77 times
- Pete -
Post by - Pete - » Fri Apr 24, 2020 2:44 pm
The curse words need to be uttered in the correct dialect of Swedish, as per ViDA.
2001 V70XC 146k
2004 V70 AWD 141k
2004 V70R M66 144k
2004 XC70 287k
2006 XC70 155k Sold
Trinidad & Tobago
Post by abscate » Sat Apr 25, 2020 5:02 am
Link to common Swedish swear words
https://hejsweden.com/en/swedish-swear-words/
Javla Tyskar!
