Battery quick disconnect for the XC 90?
Aznav
Year and Model: 2004 XC90
Been thanked: 3 times
Post by Aznav »
Does anyone know if there is such a thing to enable me disconnect the battery without having to spend 3+l minutes moving boxes, coaxing the first cover off, unscrewing three bolts, etc? Man, that would be such a help. Thanks!
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
There are switches but these usually sit directly on the battery posts. I personally tossed that battery cover long ago (but I don't have boxes inside the trunk) www.youtube.com/watch?v=lMT1RdnkxnY
There is also a power cable inside the engine bay, perhaps above the ABS unit, but not sure if this cuts the power to the entire car - but if so, may try to install a power switch at this place - this will need to be taken care by a professional
I would add, if you go with a switch, get a quality one, not one of those cheap chinese stuff. And we also may want to have the key in POSII when switching the power on/off
RickHaleParker
Been thanked: 979 times
Post by RickHaleParker »
A latching disconnect relay requires no power to stay open or closed. A magnet holds it open. A spring holds it closed. Solenoid pull/pulls it in and out of the magnetic field.
You could mount the activation switch in a convenient location, push button operation.
Intellitec 01-00055-000. $34.00 + a cable.
Specifications: 100A 12V Continuous Duty
Actuation current 3.0A
Min actuation voltage 9.0V
Max continuous carry current 100A
Max short term carry current (30 secs) 500A
Ambient temperature -40 to + 85C
Contact life at full load Min 10,000 cycles
Intellitec 01-00055-000 service manual.
Active
Past
RickHaleParker
If you want to get fancy, spurge $5.00 more and wait for it to come from China. You can get a remote controlled disconnect relay that will do 180 Amp continuous and surge to 1000 Amps. Looks like standby current is 8 milliamps.
Active
Past
