Did you know? 🤔
1998 V70 inner tie rods
woodycaldercloggs
Year and Model: v70 1998
Has thanked: 22 times
Been thanked: 0
woodycaldercloggs
Post by woodycaldercloggs » Thu Apr 16, 2020 5:04 am
About to start a job on my 1998 V70 - changing the inner and outer tie rods.
I've had a look and I am struggling to see how I can get a tool in there to hold the Steering Rack while loosening or tightening the inner tie rod on the driver side.
Any clues or ideas would be welcome. :?:
amblerman
Year and Model: 1999 s70
Has thanked: 1 time
Been thanked: 35 times
United States of America
amblerman
Re: 1998 V70 inner tie rods
Post by amblerman » Thu Apr 16, 2020 9:26 am
For me, I used two pipe wrenches and it was a tight fit.
My neighbor had an offset pipe wrench that helped.
To give you an idea what I did, watch this:
It's on a truck but the principle is the same.
Here's another variation with MUCH better lighting.
In the second video, he uses a combination of a pipe wrench and vice grips. Vice grips would not have worked for me.
Also in second version he takes off one end of the control arm to gain more working space. I can't remember if that would have helped on our Volvos or not.
woodycaldercloggs
Been thanked: 0
woodycaldercloggs
Post by woodycaldercloggs » Thu Apr 16, 2020 11:09 am
Thanks for your response.
Problem is - I don't have access to a car lift to enable me to get under it and work like that.
xHeart
Year and Model: 13XC90/01V70X/97N854
Has thanked: 20 times
Been thanked: 39 times
xHeart
Post by xHeart » Thu Apr 16, 2020 11:19 am
woodycaldercloggs wrote: ↑
You will need to raise the front safely, and set it on a jack stand. It can be done. Here is another example:
viewtopic.php?f=9&t=88332&start=40
Golden Retriever | 2014D VIDA DiCE | 2013A XC90 +144mi/231km | 2001 V70XC 1st Owner +196mi/ +315km | 1997 Volvo 850 NA 1st Owner +180mi/ +289km
Past: German Shepherd | 1989 Volvo 740 GL | 1979 Volvo 240
amblerman
Has thanked: 1 time
amblerman
Post by amblerman » Thu Apr 16, 2020 11:46 am
I don't have a lift like that either. I did mine in my driveway on jack stands.
If you don't have a way to lift the car securely high enough that you can get under it, this job will be extremely difficult to perform.
Might be impossible without some way to lift car 10 inches or so.
-A
amblerman
Has thanked: 1 time
amblerman
Post by amblerman » Thu Apr 16, 2020 11:51 am
xHeart wrote: ↑
I have to admit I don't understand what is going on in that picture. One pair of locking pliers seems to be secured to the adjustment knob of the other pair of locking pliers? Am I seeing that correctly? If so I don't know how that helps or what it does. :-)
amblerman
Has thanked: 1 time
amblerman
Post by amblerman » Thu Apr 16, 2020 12:46 pm
I understand what is going on now.
In the below picture, the yellow arrow points to a hole on a special tool for a ratchet.
That special tool is just a clamp around the tie rod and the hole is for a ratchet used for for unscrewing the tie rod.
The red arrow points in the direction you'd apply force to the locking pliers #2. That would tighten the adjustment screw on the pliers #1 attached to tie rod. Because the direction of force would tighten the adjustment knob, it would also hold the pliers #1 steady and help counteract the force applied through loosening tool (yellow arrow).
I suspect there are two sets of locking pliers in the mix just because of the cramped space and using 2 pliers allowed for a more convenient method of holding things properly.
I have to say, I haven't see that type of tool before (yellow arrow). Very cool.
Eddystone
Year and Model: 1967 Ford GT40 Mk IV
Been thanked: 25 times
Eddystone
Post by Eddystone » Thu Apr 16, 2020 1:25 pm
1998 V70 Non-Turbo/Auto
1993 945 Turbo/Auto
1999 S70 T5 Turbo/Auto
All U.S. market models.
All on the road and running.
PM me if you are near Philadelphia.
woodycaldercloggs
Been thanked: 0
woodycaldercloggs
Post by woodycaldercloggs » Thu Apr 16, 2020 1:41 pm
Once again - many thanks for your response.
One other question. Does it normally need a lot of effort to loosen the inner tie rod - I have read some others methods of doing this job and they don't seem to bother holding the steering rack at all.
xHeart
xHeart
Post by xHeart » Thu Apr 16, 2020 4:57 pm
How many miles you have on this car? Tie rods too take effort if it is your first time.
viewtopic.php?f=1&t=52978&start=20
It takes preparation. There is always a chance that steering gear may fail with DIY, viewtopic.php?f=1&t=54721&start=30
