From research it looks like these bolts changed to M6 with a boss at the top shank in 1999
There is also a third bolt with big rubber washer for the rear, inner timing belt plastic shown
You can clean the plastic while you remove the water pump you just installed by mistake as it has to go on first.
Further research. There is a mid 1998 chassis break on the tensioner that’s changes both the lower engine guard plate and the flange screws
Don’t lose these !
1999 lower timing belt guard bolts
- Been thanked: 4064 times
- 23 Replies
- 4733 Views
- 2350 Views
Last post by j-dawg
- 1296 Views
Last post by Nevada1906
- 4683 Views
- 2821 Views
Last post by chrism
