Infotainment System Blank screen
wellomal
Year and Model: 2013, Volvo S60
Has thanked: 1 time
Post by wellomal »
Hi All
Need your help/inputs, my infotainment system has stopped working, the screen is blank , as if there's no power. My AC still works but radio and all do not work at all.
However , we checked the fuse and its working fine. Is there any other way to check before going to the car agent :shock:
My car is Volvo S60 2013.
Thanks in advance for the help!
ber5ien
Year and Model: XC60 2015
Post by ber5ien »
I have got similar issue IAM is not activating caused by me resetting DTC while the battery was low.
Have you tried removing audio circuit breaker?
yagger
Year and Model: V60 2016
Has thanked: 6 times
Been thanked: 39 times
Post by yagger »
Not easy to say you guys what happened with your audio without some additional data from diagnostic. Do you have DiCE and VIDA?
ber5ien
Post by ber5ien »
Yes I got Vida and dice now. MOST test is ok only IAM is showing not active.i got vdash as well. Only PAC module shoes that cannot communicate with IAM module
yagger
Post by yagger »
I can check and give you some advice after I check everything myself. We can connect to your car online for this.
wellomal
Has thanked: 1 time
Post by wellomal »
ber5ien wrote: 18 Apr 2020, 13:40 I have got similar issue IAM is not activating caused by me resetting DTC while the battery was low.
Yeah ive tried removing the audio circuit breaker , still doesnt work :?
ber5ien
Post by ber5ien »
yagger wrote: 19 Apr 2020, 13:36 I can check and give you some advice after I check everything myself. We can connect to your car online for this.
Hi Yagger,
What is your timezone ? I could setup some TeamViewer session or anything else the VM which runs vida.
Many thanks
Raf
yagger
Post by yagger »
ber5ien wrote: 21 Apr 2020, 04:39 What is your timezone ? I could setup some TeamViewer session or anything else the VM which runs vida.
Pacific timezone. (California)
ber5ien
Post by ber5ien »
Ok so it is -7 hours from my one.
What will be a good time for you?
yagger
Post by yagger »
Do you have a skype, viber or telegram ?
