Did you know? 🤔
Infotainment System Blank screen
Help, Advice, Owners' Discussion and DIY Tutorials for the groundbreaking new Volvo S60 2011+, V60 2015+ XC60 2010-2018.
ber5ien
Year and Model: XC60 2015
Has thanked: 0
Great Britain
ber5ien
Re: Infotainment System Blank screen
Post by ber5ien » Wed Apr 22, 2020 2:45 am
I will PM you my skype
wellomal
Year and Model: 2013, Volvo S60
Has thanked: 1 time
Been thanked: 0
Brunei
wellomal
Post by wellomal » Wed Apr 22, 2020 3:29 am
Hi just out of curiosity whats the box underneath the passanger seat?
Update on my part ( sorry i dont know so much about cars) : sent the car to a workshop and they did the diagnostic, they said theres faulty with the radio module control or something. just wondering what they meant by that? when i asked them if they can fix volvo they said they cant.
ber5ien
Has thanked: 0
Great Britain
ber5ien
Post by ber5ien » Wed Apr 22, 2020 3:34 am
The module under the the seat is DAB I believe. In my situation it seems to be fine.
I have uploaded some photos.
I had some issues with Car Antenna, Parking Sensors but I have fixed those :). The car antenna was causing Volvo On Call Service Required and parking sensor had a damaged/cut cable.
https://ibb.co/MfX70pM
https://ibb.co/rtrhsVN
And info from Vdash (already cracked CEM)
https://ibb.co/tMgjMc6
Vdash actually don't even see it
These users thanked the author ber5ien for the post:
wellomal
wellomal
Has thanked: 1 time
Been thanked: 0
Brunei
wellomal
Post by wellomal » Fri Apr 24, 2020 9:07 pm
I see! So this box underneath ( https://hernvf9-my.sharepoint.com/:i:/g ... A?e=XpdDfh ) is the DAB ? im not sure if its the cos of the cable, if you look closely its already worn out.
I just wanted to check if its the worn out/damaged cable not the actual part before i buy the part :)
ber5ien
Has thanked: 0
Great Britain
ber5ien
Post by ber5ien » Sat Apr 25, 2020 12:51 am
Hi I actually had a look yesterday I found dab in my boot XC60 2015. Have a look?
wellomal
Has thanked: 1 time
Been thanked: 0
Brunei
wellomal
Post by wellomal » Thu Jun 11, 2020 7:09 pm
he mentioned it is these cables
Hi, so i have replaced the ICM display recently , and it worked for like 10 sec then it switches off, it happened quite a few times when i want to use the car.
The workshop i went to, that helped replaced mentioned , it is probably the cables cos they have tried to play around with the cables and it worked for a while. then they installed back, and again it worked for like 10 secs then it switches off.
My question is, is it really the cable?and if it is whats the name of the cable items?
ber5ien
Has thanked: 0
Great Britain
ber5ien
Post by ber5ien » Fri Jun 12, 2020 10:21 am
Perhaps worth getting multiplier and see if there isn't a drop in voltage on the cable?
Maybe Theft protection for most needs taking off. Your screen looks completely different to what i got i only got two cables in vidoe (blue) and power.
The Theft protection works in the way that it shut down the unit after 30 second if the serial number does not match with the CEM but it should display in VIDA the error message.
For example in my case replacing the screen does not make any difference probably because it's just display for me.
