So, I am getting a pronounced vibration at stoplights when in gear, that disappears when I shift to neutral.
The front lower engine mount, the one under the crank pulley, appears to be fine, as far as structural integrity goes, but was bathed in leaking oil (front cam seals?) and the front bolt was not snug. Because it had likely been marinating for a while and I believe oil and rubber don't mix, I am inclined to replace it.
The transmission torque mount is good (original), but I removed it because I assumed it was the root cause of the problem -- not true.
When I removed the transmission torque mount, the engine/transmission appears to have shifted toward the front of the car by about an eighth of an inch (enough for me not to be able to rethread the rearmost transmission torque mount bolts fore and aft).
Finally, I compared the height of the front subframe bushings (only the two forward most ones). The passenger side appears to be about and eighth to a quarter of an inch lower than the driver's side.
Preliminary conclusion is perished subframe bushings. (Upper torque rod mount previously replaced, although not particularly recently) and shows no obvious signs of bushing failure.
Thoughts?
'99 V70 Auto, Base, 234K -Front Subframe Bushings Shot?
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- dono
- Year and Model: 04 V70&XC70 2.5T AWD
- Has thanked: 43 times
- Been thanked: 6 times
Hi ES,
DW from Virginia - I know this is an old post of yours but I do have the CAM tool if you need to replace the CAM seals. Did mine on my 04 V70 and it wasnt too bad at all(in my case it was the actual exhaust CAM that had worn and was leaking not the seal). Glad to lend it to you just let me know
2004 V70 AWD Wagon 2.5L L5 DOHC 20V TURBO 268k mi
2004 XC70 AWD Wagon 2.5L L5 DOHC 20V TURBO 155k mi
1999 Mercedes e320 4Matic 238k mi
2008 Toyota Avalon XL 165k mi (meh)
- E Showell
Car was sold a while back.
'95 855 auto (sold)
'95 855 auto (sold)
- 2334 Views
Last post by theWIFES_S70
- 15 Replies
- 11537 Views
Last post by volvolugnut
- 465 Views
Last post by AVOIT17
- 2953 Views
Last post by 800artfreed
- 25 Replies
- 9022 Views
Last post by brunocerous
