Did you know? 🤔
fuel hose between pump and filter
5rivers
Year and Model: V70 1998 base FWD
Has thanked: 0
Been thanked: 3 times
United States of America
5rivers
Post by 5rivers » Wed Apr 22, 2020 5:32 pm
Greetings all,
I have had the misfortune of needing to replace the fuel filter on my 98 V70 and noticed a bulge in the hose between the pump and filter, closer to the filter. I had quite the time getting the filter off as the quick disconnect connections were not abiding by the intended purpose. Anyway, in the process I noticed a worm clamp attached to the end of the connection where it was inserted into the hose. I can only imagine when this was done and done to save $$$. Between the pressure release valve and the filter, at the end of the connection where it was inserted into the hose, was the bulge in the hose. It did not take much to shatter the bulge leaving a crack about one inch+ long.
Questions:
What do I do next and should I consider dropping the tank to get at the rest of hose.
I managed to get out all of the tip of the quick disconnect connection that was inserted in to the hose (it broke off whilst removing the filter!).
What can I manufacture, as far as connecting the fuel hose to the filter, so I can get the car back on the road. I do have one of those quick disconnect connections that attaches to the tip of the filter.
I am afraid the crack resulting from the bulge has left little room for the hose to reach the filter with the connection attached. Is there any wiggle room in the hose, i.e. can I stretch it enough to make up the space difference.
Thanks, in advance, for your recommendations!
Has thanked: 315 times
Been thanked: 972 times
Trinidad & Tobago
Re: fuel hose between pump and filter
Post by abscate » Wed Apr 22, 2020 6:38 pm
Kally, find my thread on the gas tank removal on the 1998 and see if I have the parts you need in that picture.
I call that car Clarke if that helps the search
I’ll look too. I think if you take off the plate in the rear you can connect the part and push it forward to the filter without dropping the tank.
On edit: found it and bumped thread
Link To Volvo Glossary
