Volvo 850 temp gauge dead
chrillew
Year and Model: volvo 850 T-5R 1995
Been thanked: 2 times
Post by chrillew »
Hey
The temp gauge has been really intermittent so replaced The etc and termostat. But to no help.
The months passed and The temp gauge started to not work more frequently.
And now its been dead for a long time.
So got a new cluster and thought i just replace The temp gauge itself. But how do i get the needle of, is it just pulling it off. But seems stuck.
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
You have a '95....so you still have obdI under the hood.
Check codes for instrument cluster.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
chrillew
Post by chrillew »
Yes i did try that, in port a7. But The diod only blinks once Quickly. So cant read them out.
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
You could just swap the whole cluster. Or move the odometer over to the new cluster with the working temp gauge.
chrillew
Post by chrillew »
Ye think thats easier. But i cant even reset The servicelight.
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Yes you can simply pull the needle off. I have replaced the gauge on the back of the cluster in the past to fix an issue.
The problem with swapping the cluster is that you loose the correct mileage that is stored in the cluster.
chrillew
Post by chrillew »
Is it stored digital, or can i just swap the mechanical odometer thingy with gears over to get the old correct mileage ?
misha
Post by misha »
Mileage follows the cluster.
You can correct it manually on the odometer gears...but true mileage is written digitally in instrument cluster module.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
chrillew
Post by chrillew »
Instrument cluster module where is that located? So True mileage Will be affected or not?
misha
Post by misha »
In the cluster.
True mileage will remain stored digitally in the cluster module.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
