Did you know? 🤔
Volvo 850 temp gauge dead
chrillew
Year and Model: volvo 850 T-5R 1995
Has thanked: 0
chrillew
Post by chrillew » Fri Apr 24, 2020 5:50 am
Hey
The temp gauge has been really intermittent so replaced The etc and termostat. But to no help.
The months passed and The temp gauge started to not work more frequently.
And now its been dead for a long time.
So got a new cluster and thought i just replace The temp gauge itself. But how do i get the needle of, is it just pulling it off. But seems stuck.
misha
Has thanked: 56 times
Been thanked: 134 times
Serbia
misha
Re: Volvo 850 temp gauge dead
Post by misha » Fri Apr 24, 2020 6:48 am
You have a '95....so you still have obdI under the hood.
Check codes for instrument cluster.
'91 Citroen XM 2.0 SI /fully equipped/mandarine red metallic
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
chrillew
Has thanked: 0
chrillew
Post by chrillew » Fri Apr 24, 2020 7:40 am
Yes i did try that, in port a7. But The diod only blinks once Quickly. So cant read them out.
Has thanked: 95 times
Been thanked: 278 times
United States of America
Post by erikv11 » Fri Apr 24, 2020 7:50 am
You could just swap the whole cluster. Or move the odometer over to the new cluster with the working temp gauge.
'96 855 NA, 145k
'98 V70, T5 tune-injectors-turbo, LPT engine, 286k
'06 S60 R, 167k
'99 Camry V6 :shock: 125k
chrillew
Has thanked: 0
chrillew
Post by chrillew » Fri Apr 24, 2020 7:53 am
Ye think thats easier. But i cant even reset The servicelight.
rspi
Has thanked: 22 times
Been thanked: 49 times
rspi
Post by rspi » Fri Apr 24, 2020 10:14 am
Yes you can simply pull the needle off. I have replaced the gauge on the back of the cluster in the past to fix an issue.
The problem with swapping the cluster is that you loose the correct mileage that is stored in the cluster.
'95 855 T-5R M, Panther - 22/28 mpg
'98 S70 GLT, Lil' Red 25/32 mpg
chrillew
Has thanked: 0
chrillew
Post by chrillew » Sat Apr 25, 2020 7:28 am
Is it stored digital, or can i just swap the mechanical odometer thingy with gears over to get the old correct mileage ?
misha
Serbia
misha
Post by misha » Sat Apr 25, 2020 11:45 am
Mileage follows the cluster.
You can correct it manually on the odometer gears...but true mileage is written digitally in instrument cluster module.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
chrillew
Has thanked: 0
chrillew
Post by chrillew » Sat Apr 25, 2020 11:58 am
Instrument cluster module where is that located? So True mileage Will be affected or not?
misha
Serbia
misha
Post by misha » Sat Apr 25, 2020 12:34 pm
In the cluster.
True mileage will remain stored digitally in the cluster module.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
