850 Is is possible to convert rear Drums pads to disks brakes Topic is solved
manovlov
Has thanked: 674 times
Been thanked: 164 times
Post by manovlov »
Hy Buddies,
All is is the title.
Cheers
Manov
FLXC90
Year and Model: 98 V70 T5
Has thanked: 16 times
Been thanked: 45 times
Post by FLXC90 »
I was unaware that they made 850s with rear drums, or are you asking if you can make the discs operate the parking Brake?
If your car came with drums, you would need a disc brake parts car, and swap the components over. Probably at the hub. Everything from the backing plate, the hub, bearings, discs w/drum for parking brake, out to but not including, the rim. Maybe even the master cylinder, or a brake proportioning valve at the front.
Current Volvos:
Has thanked: 2205 times
Been thanked: 1852 times
Likewise, don't think there are rear drums on an 850 other than the parking brake drum/shoes. The rear brakes are disc/pad with the drum built into them.
manovlov
Post by manovlov »
Yes i was wrong, sorry guys...
