Hello - long time lurker, first time I've asked a question. I appreciate all the knowledgeable folks here and love reading through the threads. So to kick this off, here's some background - sorry if this is long:
05 XC70 163K miles, has been in the family since '08. Never had a problem until last year around 155K, when lots of problems kicked in seemingly at once. The short of this is car died, had it towed to a local indy volvo-only mechanic (well known among volvo owners around here, unfortunately he's retiring). He said CEM, we sent it to Xemodex based on what I read here, I installed fixed CEM, all good for around 5 months.
Fuel pump died - kind of knew this was coming, replaced via FCP Euro. All good for a few more months - fuel press. between 50 and 55 psi, now have a strange crank-no-start problem. I'll give as many details as I can at this point:
1. have zero fuel pressure @ rail. It trickles out when depressing schrader valve. I have not tested it @ the valve behind the fuel filter though. I have a fuel press. gauge, shows nothing at POS II or crank (which is correct based on the schrader valve test)
2. There are no codes, I have access to Vida. Running a fuel pump test out of there I can hear the relay click and the fuel pump spin. When I put the key in Pos II the fuel pump does not kick in, it used to run for a little before starting and I could hear it.
3. have replaced FPS, no luck
4. have swapped a PEM in from another working volvo in the family (06 XC70). no luck
5. Battery is new
6. Fuses are good as far as I can tell
This *seems* like an electrical issue somewhere, but I'll be damned if I can find it. Any pointers - or at least a "jumping off point" would be much appreciated.
Thanks!
05 XC70 Fuel Delivery Problems
skeeter506
- Year and Model: 2005 XC70
05 XC70, 08 XC70, 13 Tundra, 15 JK Wrangler
- darrylrobert
- Year and Model: 2001 v70xc M58
- Been thanked: 27 times
Did you install the pump yourself, was it a genuine bosch pump?..
My first attempt i broke one of the pipes trying to squeeze the pump in that small hole, resulted in the car starting but not enough fuel to drive.
I would test the pump is actually working/not blocked/hose kinked/rubbish by jumping the pump wires under the rear seat, have someone checking the relief valve at the same time. The valve near the filter check is a good idea also.
If that fails you may need to re-install the pump..
1981 260 GLE converted to 240 M46 after auto box failure
1987 740t auto converted to M47
1997 V70t5 auto converted to M56
1998 V70 factory M56 (parts car)
2001 XC70 factory M58
2002 XC70 auto (parts car)
skeeter506
I installed the pump myself along with a fuel filter a few months ago, have done this on another xc70 as well. It's a tricky process routing that hose through the saddle tank even w/a messenger line. Weather permitting I'll pull the pump today and check it out. Thanks for the feedback!darrylrobert wrote: 24 Apr 2020, 21:21 Did you install the pump yourself, was it a genuine bosch pump?..
- 903 Views
Last post by lummert
- 12 Replies
- 2156 Views
- 29 Replies
- 5026 Views
Last post by 93Regina
- 1426 Views
Last post by mrbrian200
- 22 Replies
- 7021 Views
Last post by Scraftatx2337
