Hello,
Curious if any folks know if there exists a source for new viscous couplers for 98-00' V70XCs or if they can be rebuilt? I have seen them rebuilt for other vehicles but don't know if its possible for these cars.
If not, I'm hoping there exists the possibility of purchasing other aftermarket units and installing them in these cars.
Best,
Eric
Viscous coupler rebuilds for 98-00 V70XCs
- Has thanked: 2202 times
Not aware of any aftermarket VC units. Also do not believe there is any way to repair the VC unit itself as it is a sealed unit.Volvo did sell them but not sure if they still have stock. If you buy one make sure it has been stored upright. Dealer foreman said they had issues if the weren't as the fluid does not stay in the clutch and they will fry immediately once installed.
I wish you luck.
Oh, and I would need to check if they are all the same. I know 97-98 are different to 99-00. They have different flanges if I recall.
I wish you luck.
Richard99
- Year and Model: 2000 V70XC
- Has thanked: 26 times
- Been thanked: 23 times
Darn. Just wish I could rebuild it or replace system with something else that might work.
Eric
1998 Volvo V70 - rear-ended and totaled
2000 Volvo V70XC
2007 Volvo V50 T5 AWD M66
2000 Volvo V70XC
FlyingVolvo
- Has thanked: 51 times
- Been thanked: 74 times
You'll probably have to find a used unit somewhere. Going to be hard to find likely and of questionable condition at this age and potential mileage. Unless you really really want the AWD, which is not amazing on this car to begin with, I'd just remove the drive shaft and call it good. Odds are you'll also eventully be replacing the drive shaft and angle gear, as all are fail points.
I've been running FWD on mine with no driveshaft and angle gear removed for almost 10 years and haven't looked back.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
You could try vandsautodismantlers in Sacramento. Specialist Volvo and Saab breakers. I know one person found them hard to deal with but I did not.
- 645 Views
Last post by 850 LPT
- 849 Views
- 401 Views
Last post by wizechatmgr
- 24 Replies
- 4157 Views
Last post by amblerman
- 34 Replies
- 18119 Views
