2000 V70 Starting and then Stalling 2 seconds after.
thomasanddaboys
- Year and Model: 2000 V70
- Has thanked: 3 times
My 2000 V70 has been having a strange issue for the past few weeks. When I turn the key in the ignition, it starts fine and then approximately 2 seconds after starting it dies again. This happens consistently until the battery no longer has enough juice to turn the engine over. If I connect jumper cables the engine starts fine and runs with no issue. I took it to a mechanic to have it looked at, and he told me the problem was the battery, which I had replaced, but the problem is persisting. Has anyone seen this before or have any insight into what the issue might be?
- misha
- Has thanked: 152 times
- Been thanked: 402 times
If it starts and keeps running when battery is jumped with jumper cables and they are still attached to battery terminals...that means that your alternator is not charging and can't keep the engine running.
If you didn't mentioned jumper cables i would say that it's a classic immobiliser problem.
Are battery clamps tight on terminals?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
thomasanddaboys
So it keeps running after being jumped, even when the cables are removed.
Battery Clamps are tight on terminals.
Thank you for your response.
- misha
Let's resume this....
Does the car start and run after battery is being jumped and jumper cables removed...and will not stay running when started without jumper cables?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
thomasanddaboys
Yes exactly
- Has thanked: 1500 times
- Been thanked: 3812 times
Lets get some voltage measurements on the B+ terminal at the battery, and also at the main fuse box.
ME7 cars do not like batteries with so so voltage.
- misha
Ok....like abscate said...you will need a digital multimeter.
Before we proceed further....when you jump the battery...do you connect both jumper cables on battery terminals(+ on + and -on-)....or you connect negative jumper cable to the engine or chasis?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- 1832 Views
Last post by RickHaleParker
- 1205 Views
