Hello All.
My project is a radiator replacement on a 2008 S60 2.5T FWD. I have done a C70 Turbo twice, this is a bit more complicated. I could use a tutorial if any one has one.
Ive got it on ramps and plan on a bottom removal. First question is does the top "plate" need to be removed....part of the front bumper cover attaches to it...and if so, does it need to be completely separated and if so, what is the best way to go about it.
I am sure I will have more questions, but feel free anyone (please!) to chime in!
2008 S60 2.5T FWD Radiator Replacement Help!
- - Pete -
- Has thanked: 81 times
- Been thanked: 178 times
Hi,
The easiest way is to take it and the intercooler out through the bottom. If your jack stands are tall enough, this is the way to go. Remove it and the intercooler as a “pack”.
Below is a link to instructions for installing a larger intercooler/radiator, but the process is the same for stock sized parts.
https://www.do88.se/bilder/artiklar/pdf/ICM-160.pdf
I have a link for doing just the radiator, but it is vastly more detailed & lengthy as a process.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
volvooh
- Year and Model: '98 S70, '05&'08 V70
- Been thanked: 4 times
Thank you Pete. So, if I am reading this correctly, only the intercooler and radiator are joined? When I did this job on a C70 the A/C condenser was part of the whole "sandwich" that dropped down (radiator, intercooler and condenser).
Also, is the fan shroud coming out as well?
I have it up on ramps, so we should have plenty of room to work.
- - Pete -
Fan shroud comes out the top, then the rest comes out the bottom. Yes, you are correct that the condenser is part of the shammich - it would be the bread. But you want to separate the other two from it, then drop the rad & IC out. It talks about disconnecting the condenser from the other two in that PDF link.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
volvooh
Got it. I went back and took another look and saw where it disconnects from the condenser. On the C70 I did, the entire sandwich dropped. then the components were separated. This looks like it could be slightly less complicated.
- Been thanked: 504 times
Can someone help with PNs for hose clamps?
- UPPER hose: 2 clamps seem to be same size
- LOWER hose: 2 clamps are diff in sizes for sure.
Thanks!
Thanks!
- 123 Views
Last post by volvolugnut
- 1998 Views
Last post by Lelica
- 1741 Views
- 1374 Views
Last post by slowtype
- 7311 Views
Last post by Steve H
