Vida question..knock knock..
darrylrobert
Year and Model: 2001 v70xc M58
Been thanked: 27 times
Post by darrylrobert »
Took me a few hours but i now have Vida. I can see alot of fault codes that wasnt showing with my scan tool. I have both knock sensors with fault codes at some stage, but when there no dates, the time of fault is greyed out. anything i need to set.
Could a faulty knock sensor be causing my hot start problem
Vida xc70
Vida xc70
1981 260 GLE converted to 240 M46 after auto box failure
1987 740t auto converted to M47
1997 V70t5 auto converted to M56
1998 V70 factory M56 (parts car)
2001 XC70 factory M58
2002 XC70 auto (parts car)
RickHaleParker
Been thanked: 977 times
Post by RickHaleParker »
Clear all the codes, drive the car, see what comes back.
Active
Past
Has thanked: 1609 times
Been thanked: 4063 times
Knock sensor failures are really rare, and won’t cause starting- problems.
The only knock sensor failure I think we had here was a broken wiring harness
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
In the year or two up to changing the electrical side of my ignition switch, I got a few knock sensor codes with some sporadic rough running. Could be ignition switch electrical side on the way out. How many miles on the electrical half of the ignition switch?
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
RickHaleParker
To set up your screenshots to automatically save to OneDrive, right-click the OneDrive icon on the taskbar and select Settings. Then select the Backup tab and under the “Screenshots” section check the “Automatically save screenshots I capture to OneDrive” box and click OK.
To take a Screenshot use the [PrntScrn] key.
Works a lot better then trying to take a picture of your screen with a phone. Less work then cut and paste from the clipboard.
Active
Past
On Mac use CMD 4
Then you can use the cursors to just grab the picture you want, and then no one else will see your pornography tabs.
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
On a related topic, I don't see the Volvo DICE sold on ebay any longer.
If you go to ebay and enter "Volvo DICE", the usual device (shown in the photo in the 1st thread above) is no longer sold on ebay.
The DICE was usually on sales for about $75-$90 or so.
Here is an example of the search result:
https://www.ebay.com/sch/i.html?&_nkw=v ... e&_sacat=0
