Coolant soaked floorboard soundproofing foam
smacknab
Year and Model: 99 s70 NA Manual
Has thanked: 73 times
Been thanked: 21 times
Post by smacknab »
Hey friends while doing my AC evaporator I pulled back the driver's floorboard and found it was soaked in coolant. I replaced the heater core about 3 months ago and my coolant level has been steady since then. I'm assuming this coolant is left over from the old leaky core, or from my installation. Either way it was so soaked I cut out a square of the worst parts and I'm gonna try to clean and wet vac it, but I'm wondering if anyone knows an acceptable foam replacement. I'm thinking something from home Depot or available online. Alternatively I might go cut out the floor foam from a junkyard car in a week or two.
99 s70 NA Manual - >223k miles
Mods: Accidental C70 Delta link, V70 Left Dog Leg
Has thanked: 416 times
Been thanked: 1276 times
Re: Coolant soaked floorboard soundproofing foam
I think that is closed cell - if you can find a kiddie pool you can soak it three times, and then pronounce it coolant free.
I think I have foam from the 1998, too
Link To Volvo Glossary
Has thanked: 22 times
Been thanked: 287 times
Chances it is either from before the core was replaced or leakage from doing the swap out. As you are in there, check the 'O' ring seals at the connection for the heater core for telltale drip runs. If yo have none and coolant level is staying level the you should be ok. I had one of my cars with a leaking core when bought. Used a shop vac and then a carpet cleaner with carpet soap. Cleaned up well. Like abscate I believe it may be closed cell foam.
2006 XC70
2015 Kia Sportage EX-L
2000 V70 SE NA - New project and test bed - Sold
my98s70glt
Year and Model: 98 S70 GLT; 07 V70 2
Has thanked: 9 times
Been thanked: 5 times
Post by my98s70glt »
I experienced same issue with my car... previous owner changed the heater core a few years ago and never dried the passenger floorboard. I only noticed it a few weeks ago when I was installing an amp I picked up. I cut out the foam and took out the carpet... soaked with water and let hang dry for a few days in the sun then reinstalled the foam with tape. It’s dry now, so good enough for me.
Current:
1999 V70R: Signal Red/Charcoal || Snabb RIP Kit || Snabb Air Intake || Simons Axleback Dual Exhaust
2007 V70 2.5T: Snabb Fresh Air Pipe || BC Racing Coilovers
1998 S70 GLT: T5 ECU || 16T Turbo || White Injectors || Snabb RIP Kit || Snabb Fresh Air Pipe || Bilstein Touring || Eibach Lowering Springs || 17” Neptunes
Previous: 2006 V70 2.5T, 2011 C70 T5, 2012 S60 T5, 2000 S70 GLT/SE
smacknab
Post by smacknab »
Thanks for the help friends, I shop vac'd it, soaked it in hot water with bleach, vac'd again, soaked again vac'd again, then let it hang in the sun. Seems good enough for me!
